Home > Maintenance & Modifications > wiring up heated seats |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
From what I can recall the seats should only have a +ve and a -ve so just a simple switch and fused feed to the battery should do Russell
2011MY 110 XS USW Black |
26th Jan 2012 9:48pm |
jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268 |
With the current draw you will need relays and wiring to suit, there are plenty of kits on eBay starting as little as 99p
http://www.ebay.co.uk/itm/Vw-Golf-Mk3-heat...500wt_1288 Jason. |
26th Jan 2012 9:57pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
cheers guys i was hoping it would be easy i think they are a waste of time personally i can never feel it in dads 110 but then i spose if i got it and got a space in the dash for it why not
26th Jan 2012 11:41pm |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 |
Thats one part of the defender the good lady likes! 2008 110 XS CSW Stornoway Grey |
27th Jan 2012 6:36am |
I must say these seats a good but the best heated sets I ever had we're in an old Volvo 440 i used to own. Russell
27th Jan 2012 8:39am |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
Looking at the official wiring diagram, LR dont use relays on the seats, just the two switches on the dash (TD5) which switch the + side of the circuit. The seats are locally earthed.
27th Jan 2012 9:54am |
cheers paul i also done a little research this morning and found the same so it looks pretty simple to do
27th Jan 2012 10:24am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 496 |
Have a look at - http://www.defender2.net/forum/topic7679.html http://www.defender2.net/forum/topic8713.html http://forum.landrovernet.com/showthread.p...ost1609513 http://forums.lr4x4.com/index.php?showtopic=69458 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
27th Jan 2012 11:37am |
will have read cheers
27th Jan 2012 6:18pm |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 286 |
Hi Killer90 I have a complete wiring loom with switches,all you need is a fuse box live and a earth plus tap into you original loom for switches to come on with lights,I removed from a td5 XS loom.
the switches are for a tdci has they are different to a td5. would accept £40.00 posted if any good? thanks Ash |
28th Jan 2012 10:48pm |
On the Puma the supply is switched through the ignition via the 'Window lift relay' R143 which is protected by both the 100 Amp and 60Amp main links. The seats themselves are then protected by a 20 Amp fuse.
When the ignition is off the window lift relay switches the main live feed to the seats down to earth. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
29th Jan 2012 10:48am |
pm sent
29th Jan 2012 11:07am |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2021 |
Just adding to all the information already posted by PaulMc on this topic, he helped me with a kit to wire mine up, and I have put some info in the thread about My Defender.
http://www.defender2.net/forum/topic10705-180.html 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
25th Aug 2012 9:24am |
