Home > Off Topic > Karcher 620m Power Washer Help!
MartinK
My trusty Karcher 620 power washer has given up the ghost.
The power looks ok - the green light on the switch illuminates, and the motor comes on and sounds as usual.
Water comes out...but only at normal tap pressure.
Normally, when the trigger is not pressed (i.e. no flow) the motor stops until the trigger is pressed again.
But the motor doesn't stop anymore when not spraying (just keeps churning)
No leaks
No pressure at all other than normal tap pressure.
I've owned it from new, and it'sd not been abused, but it is about 10 years old!
Anyone care to help me diagnose please???
It's the model that looks like this:
All help appreciated...spares seem to be plentiful (such as espares) so I hope to avoid buying a new one...
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #119241 28th Jan 2012 12:31pm
pom
mine did that after i left in the shed and it froze.
Pom
Post #119242 28th Jan 2012 12:35pm
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
This happened to me also with two washers - a Karcher and a JCB. On the Karcher, it was left in the shed and the water in the pump froze and nackard it (all plastic). On the JCB (all metal bits) the bearings in the pump unit seized up - it was several years old.
Karcher offer up a good line of spares - everything can be bought. From experience however, parts often well exceed the cost of a new replacement.
Post #119244 28th Jan 2012 12:58pm
Sounds like the pump impellers have given up the ghost, or perhaps the drive shaft has sheared. Something like that that stops the pressure building up, which is why it runs continuosly. Darren
Post #119245 28th Jan 2012 12:58pm
Laurie
Time to buy a new one.
Don't buy Karcher again, they're penny pinching. Short hoses and leads. Even the detergent bottles are optional extras (which most shops don't stock)
Ideally, find one with a ceramic pump if you use it a lot.
....and keep it away from frost!
Post #119250 28th Jan 2012 1:12pm
treat yourself to a Sthil pressure washer Thumbs Up
Not as expensive as you would think and a 8 or 9m hose
Post #119260 28th Jan 2012 1:42pm
Zagato
Second Sthil kit. I haven't a pressure washer but petrol, hedge trimmer. strimmer,chainsaw, blower etc They are the best. The councils use them. I don't maintain mine from year to year properly (never changed a plug etc! Rolling Eyes ) but this equipment I rely upon for work always starts, it abusive proof kit Wink Pays in the long run and short term compared to some rubbish Rolling Eyes
Post #119270 28th Jan 2012 2:36pm
A quick Google suggest that a new pump set is around £86.
http://www.cleanstuff.co.uk/acatalog/Karch...Parts.html
You need to sure that's the problem, of course. Darren
Post #119336 28th Jan 2012 5:58pm
Laurie
Link doesn't work Sad
Post #119340 28th Jan 2012 6:17pm
Sorry. Now fixed. Darren
Post #119346 28th Jan 2012 6:28pm
MartinK
Wow - thanks for the replies, gents, much appreciated, I've been out on my mountain bike most of the afternoon, and came back to 9 useful replies - great forum Smile
LRA - thanks for the link - sounds like a good diagnisis to me.
Zag/BPman - I'm a fan of Stihl as well, owned one of their chainsaws (I have a wood-burning stove) for about a year now - top kit.
Martyn/Pom/Laurie - it's kept in a relatively warm garage in Aviemore...but of course it's been very cold here, so the frost may have managed to get into it I guess Embarassed
I'll try and take the pump out in the morning.
Any ideas if I can confirm (once it's taken off) if it is the pump that's the fault before I part with £86???
Post #119368 28th Jan 2012 7:27pm
pom
if it was me, I'd take use the Stihl chainsaw to repair it.
Pom
Post #119369 28th Jan 2012 7:32pm
mermoto
Get yourself a Kranzle - Thumbs Up
Mermoto
Post #119376 28th Jan 2012 7:42pm
Drew
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Mermoto
Second vote for the Kranzle Thumbs Up
Post #119990 31st Jan 2012 1:07am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Karcher is good kit, provided it isn't left to freeze. our Diesel hot pressure wash is still going very strong.
As already said the Sthil kit is bomb proof, absolutely swear by the chainsaws, strimmers, hedge trimmers and blowers.
Alex 110 Tdci Double Cab
Post #120050 31st Jan 2012 11:50am
