Home > Maintenance & Modifications > Mud Flap fitting not so simple |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Use steel poprivets.
25th Jan 2012 12:30pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Do you mean aluminium head steel shaft or 100% steel? 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
25th Jan 2012 1:25pm |
100% steel.
They drill out OK when you need to remove them. Aluminium ones are not strong enough and will corrode rapidly. |
25th Jan 2012 1:40pm |
verminhunter Member Since: 10 Dec 2011 Location: Paignton Posts: 33 |
knock the factory inserts out and fit M8 rivnut inserts, cheap as chips fit them with a nut and bolt. job done..
http://www.ebay.co.uk/itm/M8-Aluminium-Riv...1209wt_970 |
25th Jan 2012 2:12pm |
What Rivnut insert tool should I get though? They seem either really cheap and look like a pop rivet gun, or really expensive.
Will Aluminium rivnuts not corrode within the steel of the crossmember etc? 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
25th Jan 2012 2:17pm |
http://www.defender2.net/forum/topic8631.html |
25th Jan 2012 2:19pm |
they do steel rivnuts too just a little harder to compress thats all.
25th Jan 2012 4:14pm |
You get what you pay for with rivnut tools, however there is a thread to make your own. you can get steel and/or aluminium rivnuts, so use like for like HTH BP |
25th Jan 2012 7:13pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
RRUK if you want to borrow a rivnut tool give me a shout.
Brendan |
25th Jan 2012 7:27pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
TBH bar the industrial one I love the memfast one even works well with an air ratchet attached
25th Jan 2012 8:36pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
I'd try drilling out the snaped of bolt first, with look and WD40 you may get the bolt moving,
can you get a reverse thread drill bit? do they even exsist? if they do you could possably get it moving as you drill in the same direction as the thread you want to extract, if not then get it moving in and it will just drop into the chassie and leave the factory fitted rivnut in place, if that makes sence, Mark |
25th Jan 2012 10:46pm |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 |
You can get a tool similar. A thread extraction tool. Its basically like a left handed thread tap with course spirals running down a taper. Drill a hole in the bolt, gently knock the extraction tool in and using a tap wrench or adjustable spanner, remove the bolt. WD40 would help as well.
Easy in theory, but these things can be frustrating! 2008 110 XS CSW Stornoway Grey |
26th Jan 2012 1:02am |
ALDI from tomorrow (Thursday) http://www.aldi.co.uk/uk/html/offers/special_buys3_23048.htm |
26th Jan 2012 1:13am |
good find Laurie, off to the shops tomorrow
26th Jan 2012 7:23am |
