Home > Maintenance & Modifications > Mud Flap fitting not so simple
RRUK
Previous owner obviously had mud flaps but they got damaged or whatever, and so they simply snapped off the bolts in the threaded fitting holes, means I cant fit mine in the factory holes.
So, now I can either drill through and re-tap, which means buying a tapping die kit and better drills, or finding my own way of fixing them.
Did think about drilling new holes and using the biggest rivets I can find. Should hold right? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #118352 25th Jan 2012 12:22pm
Laurie
Use steel poprivets.
Post #118356 25th Jan 2012 12:30pm
RRUK
Do you mean aluminium head steel shaft or 100% steel? 2016 D4 HSE
Post #118371 25th Jan 2012 1:25pm
Laurie
100% steel.
They drill out OK when you need to remove them.
Aluminium ones are not strong enough and will corrode rapidly.
Post #118377 25th Jan 2012 1:40pm
verminhunter
United Kingdom 2000 Defender 90 Td5 SW Zambezi Silver
knock the factory inserts out and fit M8 rivnut inserts, cheap as chips fit them with a nut and bolt. job done..
http://www.ebay.co.uk/itm/M8-Aluminium-Riv...1209wt_970
Post #118387 25th Jan 2012 2:12pm
RRUK
What Rivnut insert tool should I get though? They seem either really cheap and look like a pop rivet gun, or really expensive.
Will Aluminium rivnuts not corrode within the steel of the crossmember etc? 2016 D4 HSE
Post #118388 25th Jan 2012 2:17pm
verminhunter
http://www.defender2.net/forum/topic8631.html
Post #118390 25th Jan 2012 2:19pm
verminhunter
they do steel rivnuts too just a little harder to compress thats all.
Post #118400 25th Jan 2012 4:14pm
You get what you pay for with rivnut tools, however there is a thread to make your own.
you can get steel and/or aluminium rivnuts, so use like for like
HTH
BP
Post #118453 25th Jan 2012 7:13pm
leeds
RRUK if you want to borrow a rivnut tool give me a shout.
Brendan
Post #118464 25th Jan 2012 7:27pm
TBH bar the industrial one I love the memfast one even works well with an air ratchet attached Thumbs Up
Post #118505 25th Jan 2012 8:36pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
I'd try drilling out the snaped of bolt first, with look and WD40 you may get the bolt moving,
can you get a reverse thread drill bit? do they even exsist? if they do you could possably get it moving as you drill in the same direction as the thread you want to extract, if not then get it moving in and it will just drop into the chassie and leave the factory fitted rivnut in place, if that makes sence,
Mark
Post #118565 25th Jan 2012 10:46pm
Lukey Boy
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
You can get a tool similar. A thread extraction tool. Its basically like a left handed thread tap with course spirals running down a taper. Drill a hole in the bolt, gently knock the extraction tool in and using a tap wrench or adjustable spanner, remove the bolt. WD40 would help as well.
Easy in theory, but these things can be frustrating! Wink 2008 110 XS CSW Stornoway Grey
Post #118577 26th Jan 2012 1:02am
Laurie
ALDI from tomorrow (Thursday) Very Happy
http://www.aldi.co.uk/uk/html/offers/special_buys3_23048.htm
Post #118578 26th Jan 2012 1:13am
good find Laurie, off to the shops tomorrow Thumbs Up
Post #118597 26th Jan 2012 7:23am
