Home > Off Topic > URGENT Tow Hitch Query |
chopdogs Member Since: 10 Mar 2010 Location: Wiltshire Posts: 108 |
Hi All
Got a bit paranoid before a longer journey than normal tomorrow with the horse trailer. Could you have a look at the photos and let me know if the one bolt in the hitch is what is required or whether there should be another bolt (or two) horizontally or vertically through the hitch? My thought is that perhaps there's only one so that the hitch can pivot up and down on that bolt....? Am I being a gumby? Worried I may do more harm than good if I put another bolt on there Click image to enlarge Click image to enlarge Thanks v much chopdogs |
20th Jan 2012 5:07pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Should be two bolts.
Make sure the heads are marked 'S' or 8.8 |
20th Jan 2012 5:13pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
WTF have you been towing that
Can't see a breakaway cable either |
20th Jan 2012 5:15pm |
Thanks guys
Should the extra bolt be next to thge current - ie horizontally through the hitch or vertically (there's a hole there too)? There is a breakaway cable - just tucked back I'll have Tony Bolwell sort it on Monday |
20th Jan 2012 5:56pm |
Remove the existing bolt and take off the hitch.
You'll then (hopefully) see two holes through the drawbar. These will show you where to fit the other bolt. Could be one horizontal and one vertical or both (most likely) horizontal If the bar's been shortened and there is only one hole it should not be used. |
20th Jan 2012 6:12pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Been lucky there chap the rear bolt holds the damper in place as well maybe someone has tried to steal it.
20th Jan 2012 6:17pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
I have the same type of hitch and the bolt goes in that vacant drilling and plese don't use mild steel bolts. Maybe your local caravan shop will have two for you along with two washers and nyloc nuts. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
20th Jan 2012 6:29pm |
Exactly as said above, there should be 2 bolts and personally I'd put 2 new ones in
20th Jan 2012 6:53pm |
