Home > Off Topic > URGENT Tow Hitch Query
chopdogs
Hi All
Got a bit paranoid before a longer journey than normal tomorrow with the horse trailer.
Could you have a look at the photos and let me know if the one bolt in the hitch is what is required or whether there should be another bolt (or two) horizontally or vertically through the hitch?
My thought is that perhaps there's only one so that the hitch can pivot up and down on that bolt....? Am I being a gumby? Worried I may do more harm than good if I put another bolt on there
Thanks v much
chopdogs
Post #117086 20th Jan 2012 5:07pm
Laurie
Should be two bolts.
Make sure the heads are marked 'S' or 8.8
Post #117087 20th Jan 2012 5:13pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
WTF have you been towing that Shocked
Can't see a breakaway cable either
Post #117089 20th Jan 2012 5:15pm
RED-DOT
I would replace them both before i used that again as the broken one has probably overloaded the other one... you have been very lucky indeed. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #117096 20th Jan 2012 5:47pm
chopdogs
Thanks guys
Should the extra bolt be next to thge current - ie horizontally through the hitch or vertically (there's a hole there too)?
There is a breakaway cable - just tucked back
I'll have Tony Bolwell sort it on Monday
Post #117099 20th Jan 2012 5:56pm
Laurie
Remove the existing bolt and take off the hitch.
You'll then (hopefully) see two holes through the drawbar.
These will show you where to fit the other bolt. Could be one horizontal and one vertical or both (most likely) horizontal
If the bar's been shortened and there is only one hole it should not be used.
Post #117102 20th Jan 2012 6:12pm
mick
Been lucky there chap the rear bolt holds the damper in place as well maybe someone has tried to steal it.
Post #117105 20th Jan 2012 6:17pm
RED-DOT
I have the same type of hitch and the bolt goes in that vacant drilling and plese don't use mild steel bolts. Maybe your local caravan shop will have two for you along with two washers and nyloc nuts. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #117107 20th Jan 2012 6:29pm
JWL
Exactly as said above, there should be 2 bolts and personally I'd put 2 new ones in
Post #117115 20th Jan 2012 6:53pm
