Home > Td5 > TD5 chassis loom - WTF?
Arbman Al
For the last week I gave been waiting for the chassis loom to turn up. 1st one sent out did not arrive, 2nd one arrived yesterday late afternoon, opened it up this morning, but the connectors don't match what I have.
Did the dash loom change at some state?
See photos below, dash loom came with the engine which was 2005 and chassis loom from ebay as 110 TD5
[/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #116964 20th Jan 2012 8:57am
wslr
There are 8 or so different engine looms for Td5 and at least 3 different ones for the chassis for a standard 110 (not the HiCap).
Post #116967 20th Jan 2012 9:20am
Arbman Al
I ended up just using the fuel pump wires, and the original rear loom - thank god I hadn't pulled it out Smile 1996 Defender 130 converted to TD5 and auto
Post #117186 20th Jan 2012 10:28pm
Hmmm..... I thought that the rear lighting plugs and the fuel pump plugs were all the same across the years.
The couple of Td5s i've built have all matched up, and i've used mix & match of bulkhead and chassis looms.
Unless I was just very lucky? Question
Post #117502 22nd Jan 2012 1:50pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
You were very lucky. I bought a TD5 bulkhead loom and TD5 chassis loom. One of the three plugs was completely different and from what I remember one of the "matching" plugs had a couple of different wires.
Fortunately the mismatched plug was the same as a wing loom plug so I cut the plug off a wing loom and modified the chassis loom to fit the bulkhead loom. Would have been a much easier job had I not already run the chassis loom and bulkhead loom into the vehicle before I realised there was a problem.
Post #117529 22nd Jan 2012 4:54pm
