![]() | Home > Technical > Rear Panel Access! |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
bet those heated seats are nice on the bad back aswell. |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2673 ![]() ![]() |
WHy not move the passenger wiper motor over to driver side for MOT. IIRC you only need the drivers side to be wiped to pass the MOT. Until you can sort out another motor 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
If it's fitted with two originally, they both have to work. Taking it off wouldn't work as originally it had 2
![]() ![]() ![]() Anyway it's nice to have a bit of luxury for a change after 3 winters in this... ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
There's a removable rubber sealing grommet at the bottom of the C pillar which gives good access to its interior. Access to the rear of one or two of the rivets can be acheived in the area of the rear seat base. You can also get a fine lance into the cavity via the door catch [mark the catch position with a soft pencil prior to removal] and if you really want to go to town you drill a couple of access holes into the interior pillar closures so you can get the lance in and then plug the holes with grommets. Steve.
