![]() | Home > Td5 > TD5 Def not starting as well in the freezing cold |
I think you've answered your own question,Glow plug light, turn over when it's gone out.
![]() 1968 1/32 scale Britains 109 Pick up. |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Is your fuel pressure regulator on the drivers side of the engine at the back near the bulkhead leaking at all? Can sometimes let air in causing it not too start too well.
Pete. |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
might be worth dropping some heater plugs in it if its not had any in before they can fail i fitted some and 2 had failed in just over a year,
But always let the glow light go out, even tho the light has gone out it keeps them on a little while when the engine has started Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Mine had a similar problem.
Lift the drivers seat and cover. Place your finger on the fuel pump relay while cranking. If it vibrates it's not getting enough voltage. The only way I could cure mine was to fit a new battery. |
