Home > Td5 > TD5 Def not starting as well in the freezing cold
RussB
United Kingdom 2001 Defender 90 Td5 CSW Tamar Blue
Hi, my 2001 Defender TD5 normally starts instantly first thing in a morning with little of no heat required. Lately it's been pretty cold here (below freezing) and I'm having to turn it over for a few seconds until it starts up. It sounds like its spluttering and stuggling to fire. Once started it runs great. It's as if it's temerature related as when it's even only a couple of degrees above freezing it's fine. It's almost as if the fuel is waxing or something??? When it's really cold I wait until the heater plug lights have gone out before I try and start it to at least give it more chance. Any ideas? 2001 Defender 90 TD5 CSW
1951 Series One 80'' 2.5 N/A Diesel
Post #116211 17th Jan 2012 4:21pm
Grockle
I think you've answered your own question,Glow plug light, turn over when it's gone out. Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #116235 17th Jan 2012 5:51pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Is your fuel pressure regulator on the drivers side of the engine at the back near the bulkhead leaking at all? Can sometimes let air in causing it not too start too well.
Pete.
Post #116266 17th Jan 2012 7:29pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
might be worth dropping some heater plugs in it if its not had any in before they can fail i fitted some and 2 had failed in just over a year,
But always let the glow light go out, even tho the light has gone out it keeps them on a little while when the engine has started
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #116296 17th Jan 2012 8:31pm
Laurie
Mine had a similar problem.
Lift the drivers seat and cover.
Place your finger on the fuel pump relay while cranking.
If it vibrates it's not getting enough voltage.
The only way I could cure mine was to fit a new battery.
Post #116297 17th Jan 2012 8:35pm
