Home > Maintenance & Modifications > Alko caravan towbar position?
Page 4 of 8 <12345678>
Zagato
BIG is BEST Very Happy
Post #116247 17th Jan 2012 6:34pm
WarPig
Is there any need to use a Shocklink when towing with a Defender? With the Defender's suspension being stiffer than eurobox cars, I wonder if they are a good idea. But at £400 each im hoping you all say "no" Shocked
Post #116319 17th Jan 2012 9:23pm
rossy
I wouldn't have thought so unless you plan to go greenlaning with the caravan at the back !
Post #116330 17th Jan 2012 9:42pm
JWL
Not being pedantic or anything but, let me get it straight, with these DB Shocklink adapters to my understanding take out what forces on the hitch? Now when I think of how a caravan is hitched to a tow vehicle then any shock loading being transferred from the trailer to the tow vehicle has to go through a shock absorber that is fitted anyway, it's called the overun brake!
Post #116331 17th Jan 2012 9:47pm
Laurie
Only need to consider it if you're a Series towing an aluminium chassis 'van.
Post #116333 17th Jan 2012 9:49pm
A Shockline damps vertical shocks rather than horizontal. As Laurie says though, they're more applicable to leaf sprung Series Land Rovers. They're also popular amongst folks towing horse boxes, as they give a better ride for the expensive cargo. Darren
Post #116348 17th Jan 2012 10:12pm
JWL
I allways did wonder, granted vertical loads could figure, as you say horse box tuggers may think that they are cushioning the trip for the dobbin but less of an issue nowadays with twin axles. One thing I would say is that the one in the picture is only rated to a hitch loading(nose weight) of, if I can see correctly, 80kg. My laat caravan was reccomended to have a higher weight and I'm sure that most horseboxes wouldexcwed that aa well
Post #116376 17th Jan 2012 11:08pm
JWL
Post #116378 17th Jan 2012 11:09pm
TJ101
Laurie wrote:
If anything, a Ninety tows better than a One-Ten.
The shorter distance from the rear axle to the towhitch makes the tail less likely to wag the dog.
A 110 is a far better tow vehicle due to the extra wheelbase over a 90,,
If the trailer is wagging, you have loaded it wrong California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #116381 17th Jan 2012 11:25pm
jst
i agree the longer wheel base on a 110 makes it far better for towing than a 90 Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #116382 17th Jan 2012 11:29pm
Lorryman100
WarPig wrote:
Thanks Laurie. Think I might end up upgrading to something like the Bradley hitch that Lorryman is using.
I just ordered the Dixon Bate one that Zag has to give more clearance from the cross member and the spare wheel. I'm hoping that as the Winterhoff's actuator arm is set farther back, and with the addition of this DB tow jaw the back door can remain closed whilst hitching up. Thumbs Up
Brian.
Post #116471 18th Jan 2012 1:55pm
WarPig
That makes sense Brian. I dont have my spare wheel on the rear door so I guess its not such an issue for me. I assume that apart from the spare wheel clearance issue, yours would otherwise be OK? So is your Bradley towball up for sale Brian Whistle
I see Bradley have acquired the trading name of Dixon Bate
http://www.bradleydoublelock.co.uk/news/
Post #116509 18th Jan 2012 4:27pm
Lorryman100
Hopefully I am picking the van up from the dealers at the end of next week as they have still to fit the roof mounted satellite. I was going to then interchange between the tow balls and see what one in my mind would be best, I could then offer you first refusal the other one? Though chances are I would keep both and use the Bradley one in the winter as it is smaller and not as sticky outey as the DB one. Thumbs Up
Brian.
Post #116515 18th Jan 2012 4:39pm
WarPig
A wise decision. Real men have two (tow)balls. Mr. Green
I bought a 2nd hand Nemesis wheel clamp from ebay today. Its a big heavy beast but will be ideal for use whilst my vans in storage. Might get a lighter clamp for use when touring.
Post #116516 18th Jan 2012 4:44pm
JSG
Brian.
Do you think you'll need the extra height of the neck for the Winterhoff hitch Brian?
My current towball is exactly the same as above but has the shorter neck, but if I read the specs on the Winterhoff site correctly it looks as though the lower / shorter neck may be ok
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  John
2011 Tdci 110 CSW XS
Post #116576 18th Jan 2012 7:45pm
