Home > Maintenance & Modifications > What do you use on your chassis?
RRUK
I appreciate this may only be for the die hard enthusiasts...
When I get mine I plan to prepare and paint the chassis with black satin Hammerite paint, a few coats, and then use Waxoyl afterwards, as I love a belt and braces approach to things.
I used to use Waxoyl on my Series 3 many years ago and wondered if I am thinking about this in the right way:
1. Waxoyl clear for injecting into cavities, door bottoms, chassis rails etc
http://www.halfords.com/webapp/wcs/stores/...yId_165594
2. Waxoyl Black for spraying onto exterior faces of chassis, crossmember, footwells etc
http://www.halfords.com/webapp/wcs/stores/...zone=PDPz1
What I am not sure about is whether people use the following product in the same range on the chassis, as it appears you can only brush it on rather than spray it, which seems a total faff and ball-ache. (you can buy this in an aerosol but you'd need plenty of them and be bankrupt at the end)
http://www.halfords.com/webapp/wcs/stores/...yId_165594 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #115903 16th Jan 2012 1:45pm
JSG
Read this - sticky thread at the top of this board. It will tell you all you need to know ......
http://www.defender2.net/forum/topic10467.html John
2011 Tdci 110 CSW XS
Post #115904 16th Jan 2012 1:48pm
Killer90
Site Sponsor
you can buy a tin from halfords the hammerite wax oil and also a spraying system like what they sell to paint fences pour it in and your away Smile at work we use it by the tin and is in spray form out of a gun which plugs into the air line much easier but then it is on a ramp and you can get everywhere
Post #115934 16th Jan 2012 5:36pm
