Home > Puma (Tdci) > central locking
spudfan
Ireland
central locking
Today I noticed that one of the rear passenger doors (110 station wagon) was not locking when all the other doors were locked.The push button was not going down far enough.As a purely emergency measure I put some general purpose oil down behind the push button.Anyway it worked.So I did the same to the rest of them.When I am next at the dealer I will get it checked out but if this works it will save me going down specially. I have tried it a number of times and it is working o.k.Thought I would mention it incase someone else has the same problem.
Also I remember people mentioning about their handbrakes getting hot.Last week while driving in some very cold weather I noticed my handbrake lever getting hot.I just felt it while driving.I turned off the heat and it cooled down-so did I.It seems it is caused by the hot air hitting off the bear metal on the handbrake lever. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #6598 26th Jan 2009 4:53pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I'v had problems with mine it was ok when opening but when
i locked it it used to sound like a bank volt
went to dealer thay changed it no prob.
but like you i was worred about it not locking Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #6629 27th Jan 2009 1:53pm
sib
this happened to my 130 last week. they fixed it quickly by taking off door panel and lubing all the movements. works a treat now. Sib
Bath UK
1952 80 inch
1973 88 inch
2018 Morgan plus 4 narrow body
Post #6650 28th Jan 2009 1:55pm
RgrBox
United States 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
MY problem is that sometimes the rear door won't un-lock.. also the damn thing is sensitive.. goes off in my pocket sometimes.. then the alarm goes off.. 2008 110 2.4 tdci csw
Landrovers of Switzerland Club member
Post #11549 4th Jun 2009 4:23pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
I'll do you a swap, my remote is crap. I have to be so close for it to work, I might as well use the key. New batteries don't help.
Post #11577 5th Jun 2009 7:46am
110SEB
Mine too. 3 meters if i'm lucky. Did you know holding the remote fob to your temple extends its range? You then act as an aerial to the thing and you can ping you lock at 5 - 6 meters.
God knows what it's doing to my brain. If i have one.
Post #11587 5th Jun 2009 9:21am
Bosun
I think I'll struggle on. Don't want the men in white coats to come knocking.
Post #11592 5th Jun 2009 10:12am
RgrBox
Same here.. I wish it didn't have this remote stuff sometimes...
RB 2008 110 2.4 tdci csw
Post #11600 5th Jun 2009 10:55am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
As demonstrated by Clarkson on Top Gear... hold it against your head and push the button. Vastly improves the range of the plip.
Otherwise, mines like ever other one, 3 metres is about it! All the same its a lot better when running for the car in a tropical storm, to be able to unlock with a press as you approach the Defender. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #11623 5th Jun 2009 9:49pm
Eduardo
Same here but 3-5 mt only in environment without any radio interference. In the city should be 1 meter, no more.
and as the others it is not sensitive at all Crying or Very sad
RgrBox. maybe your remote are not working well Mr. Green
Courious why LR has not improved the range of the remote lock or at least paid us a contorsionist course to get more range.
Cheers Eduardo
Post #11627 5th Jun 2009 10:38pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I can't believe we're having this conversation about the range of our remote central locking for DEFENDERS! Laughing
For the record, mine is also limited in range and angle of approach. "head shot" works well and so can "shooting from the hip".
I'm just chuffed I can do it remotely at all Smile One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #11629 5th Jun 2009 11:16pm
Grockle
The range was reduced to stop undesirables from scanning your remote frequency. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #11633 6th Jun 2009 7:59am
RgrBox
What kills me, is that the damn thing will go off in my pocket, and lock the truck while I'm trying to take something out.. but i have to bang on the damn button several times to open it when I want to open it????
RB Embarassed 2008 110 2.4 tdci csw
Post #11634 6th Jun 2009 8:18am
niglyn
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
The remote having limited distance is a fault. Mine would only work when right above the engine bay, no good if you need to open the back.
The dealer was going to change the ECU (as advised by Landrover Technical) when removed they found the antenna lead had come out of it's socket, more than likely during installation. Works from a greater distance like any other car now.
Unfortunatly I do not know the exact position of the ECU, I am guessing it is behind the drivers instrument cluster as thets where my fob worked best.
Would like to hear if this info solves the fault on other vehicles
BR,
Niglyn
Post #11890 12th Jun 2009 4:44pm
110SEB
The ECU is under the driver's seat. I wonder how obvious the aerial is? I haven't looked for it.
Post #11898 12th Jun 2009 9:15pm
