Home > Puma (Tdci) > Worklight |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
I want to put a worklight on to the Puma but need some information.
Is there a pre-existing harness on passenger's side rear to plug in to? What's the best way to run a lead from the gutter into the vehicle? If anyone has a copy of the LR fitting instructions for the OEM Worklight that would probably answer all my questions. I don't see the point in buying a genuine one though. Thanks in advance. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
14th Jan 2009 12:41am |
foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64 |
Derek,
I don't know if it's the same on the Puma as the TD5 but the auxilliary connector is on the drivers side in the wiring loom for the rear brake light, behind the speaker panel. It is a white twin female lucas connector with the conductors at 90° to each other and is fused in the panel by the gear lever (under the steering wheel in your case). I was thinking about fitting a light to mine and was just going to drill a hole in the rear roof panel and use a water proof gland. The kind sparkies use on electrical panels etc. These come in all different sizes and are theoretically the right thing for the job. Regards, Ray Land Rovers are an addiction. Toyotas are for quitters. WWW.CQLROC.ORG |
14th Jan 2009 1:05am |
Thanks Ray, haven't had that panel off yet, but I knew there was a spare cable on one side somewhere. I asked about the install as the water tight grommet was the only thing I could think off but thought there may be another way that didn't require drilling another hole. 110 2.4TDCi
14th Jan 2009 1:32am |
RgrBox Member Since: 04 Jun 2009 Location: St-Cergue, Switzerland Posts: 111 |
Mine comes threw the rear roof down the back wall under the side window, over the two passenger windows and then down into the dash.. My problem is that the passenger side from door rubber gasket doesn't fit well, and I always have to push it back up into the top of the door, it closes poorly and you can hear the outside very bad.. 2008 110 2.4 tdci csw
Landrovers of Switzerland Club member |
4th Jun 2009 5:27pm |
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 |
I drilled a small hole and then put a rubber grommet in and passed the cable through there. The hole is in roof but just above the gutter so unless you are 7ft tall you don't even see it.
4th Jun 2009 6:22pm |
I checked last night and couldn't find this extra connection? 2008 110 2.4 tdci csw
5th Jun 2009 7:07am |
you have the steering wheel on the left, "foz.in.oz" on the right....... see behind the right rear speaker panel...... |
5th Jun 2009 7:12am |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
I guess in a truck cab the connector is likely to be in the box that covers the back of the rear light cluster? Planning on fitting two lamps on the TC - one an auxilliary reverse lamp and one a switched work lamp.
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
5th Jun 2009 9:24am |
I have left hand drive.. I look at both of them, but will have a closer look this weekend. I found that my rear light was using another cable running back there. RB 2008 110 2.4 tdci csw Landrovers of Switzerland Club member |
5th Jun 2009 11:58am |
