Home > Puma (Tdci) > Worklight
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Worklight
I want to put a worklight on to the Puma but need some information.
Is there a pre-existing harness on passenger's side rear to plug in to?
What's the best way to run a lead from the gutter into the vehicle?
If anyone has a copy of the LR fitting instructions for the OEM Worklight that would probably answer all my questions. I don't see the point in buying a genuine one though.
Thanks in advance. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #6280 13th Jan 2009 11:41pm
foz.in.oz
Australia 2004 Defender 110 Td5 SW Bonatti Grey
Derek,
I don't know if it's the same on the Puma as the TD5 but the auxilliary connector is on the drivers side in the wiring loom for the rear brake light, behind the speaker panel. It is a white twin female lucas connector with the conductors at 90° to each other and is fused in the panel by the gear lever (under the steering wheel in your case).
I was thinking about fitting a light to mine and was just going to drill a hole in the rear roof panel and use a water proof gland. The kind sparkies use on electrical panels etc. These come in all different sizes and are theoretically the right thing for the job.
Regards,
Ray Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG
Post #6281 14th Jan 2009 12:05am
dm_td5
Thanks Ray, haven't had that panel off yet, but I knew there was a spare cable on one side somewhere. I asked about the install as the water tight grommet was the only thing I could think off but thought there may be another way that didn't require drilling another hole. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #6282 14th Jan 2009 12:32am
mse
Ive just looked - surprised there isnt the fitting instructions avaliable for them.
I know someone who ran a cable down the gutter to the snorkel, down that and in.
Otherwise, hook through the door or drill wire sized void. Mike
Post #6288 14th Jan 2009 10:11am
RgrBox
United States 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Mine comes threw the rear roof down the back wall under the side window, over the two passenger windows and then down into the dash.. My problem is that the passenger side from door rubber gasket doesn't fit well, and I always have to push it back up into the top of the door, it closes poorly and you can hear the outside very bad.. 2008 110 2.4 tdci csw
Landrovers of Switzerland Club member
Post #11550 4th Jun 2009 4:27pm
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
I drilled a small hole and then put a rubber grommet in and passed the cable through there. The hole is in roof but just above the gutter so unless you are 7ft tall you don't even see it.
Post #11553 4th Jun 2009 5:22pm
RgrBox
I checked last night and couldn't find this extra connection? 2008 110 2.4 tdci csw
Post #11573 5th Jun 2009 6:07am
dgardel
Italy
you have the steering wheel on the left, "foz.in.oz" on the right.......
see behind the right rear speaker panel......
Post #11574 5th Jun 2009 6:12am
NoDo$h
I guess in a truck cab the connector is likely to be in the box that covers the back of the rear light cluster? Planning on fitting two lamps on the TC - one an auxilliary reverse lamp and one a switched work lamp.
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #11581 5th Jun 2009 8:24am
RgrBox
I have left hand drive..
I look at both of them, but will have a closer look this weekend. I found that my rear light was using another cable running back there.
RB 2008 110 2.4 tdci csw
Post #11601 5th Jun 2009 10:58am
