Home > Wheels & Tyres > tyre sizes for Boost alloys
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
Probably been asked a hundred times (Idid try a search) but whats the biggest tyre you can run on a boost alloy without affecting the gearing etc and not requiring spacers.... though would consider adding spacers if neccessary?
currently running the standard Grabbers 235/85/16 and looking at getting either a set of BFGs or the new Cooper Discoverer st max Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #115584 15th Jan 2012 4:00pm
T1G UP
285s
just sold a set!
Post #115585 15th Jan 2012 4:04pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Any tyre taller than 235's will effect gearing but depends on the size. Boosts are 7 inch wide and this will restrict the tyre size.
This link will give you a guid. (click the veiw spec link on the right bottom)
http://www.bfgoodrichtires.com/tire-select...spec_table
I too have 285's running on 8.5 inch rims, if anything else it makes the speedo run true Laughing
Post #115588 15th Jan 2012 4:26pm
robpenrose
i have 265s.
Went on my standard 90 without any rubbing or modification Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #115589 15th Jan 2012 4:31pm
The common sizes are either 235/85, which is how they come from the factory, and 265/75. The latter are, as near as makes no difference, the same diameter as the former so they're interchangeable. Darren
Post #115604 15th Jan 2012 5:22pm
Reiver
England 2010 Defender 90 Puma 2.4 HT Rimini Red
Only other thing I would add Alan is the question of whether your turning circle would be compromised with wider track tyres? It'd 'ollocks at the best of times Shocked
I'm sure the others here would know, but I've just fitted 30mm spacers to get something appearing sensible. This is border country and the Romans built a wall for a reason!
Post #115606 15th Jan 2012 5:29pm
alanhid
thanks guys..... Thumbs Up just find the whole tyre thing sooooo confusing. Dont want monsters, just something slightly wider, and will put spacers on if needed. Life is not a rehearsal!
Post #115705 15th Jan 2012 7:32pm
MK
Actually boost wheels are 7.5" Puma 110" SW
Post #115802 15th Jan 2012 10:55pm
Projectblue
This old chestnut. I have run 285/75 on boosts no probs although it will affect the gearing and it doesn't catch the arches, although they can catch the radius arms on full lock.
Depends on what you are trying to achieve really.
Post #115804 15th Jan 2012 11:05pm
ngarigo
Ireland 2011 Defender 90 Puma 2.4 SW Santorini Black
265 cooper s/t maxx's on standard.... sweet...! Thumbs Up
27 by Defender 90, on Flickr Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
'Wow...! What a ride!
MY11 90
Post #115812 16th Jan 2012 3:35am
jst
so width wise you can run a 285 on a boost alloy ok? just looking for some 33" ish tyres for the 90 puma i just picked up, the 235.85s are just too small looking with the 30mm lift it has. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #478868 3rd Dec 2015 8:28pm
Martin
Site Admin
Tyres are not sized solely by width, you need to consider the height (percentage of width) as well.
This way, 235/85R16 tyres are the same overall height as 265/75R16. The overall height which is what you should aim to keep the same or very similar Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #478873 3rd Dec 2015 8:38pm
jst
Hi Martin, thank you for reply, yep well aware, i am trying to acheive a 33" ish height, the brand and tread i want only do that in a 285, just wondering if that will fit the boost rim, 7.5J is it? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #478875 3rd Dec 2015 8:42pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
255 85 16 any good for.ypu james? 2004 TD5 Defender 90 xs station wagon
Post #478903 3rd Dec 2015 9:50pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Since when?
Post #478930 3rd Dec 2015 11:16pm
