Home > Technical > Fault code logs and interpretation |
rusty66 Member Since: 22 Jun 2010 Location: Rhineland Posts: 60 |
Hi,
can anyone help with the two digit codes after the general DTCs? I've got eg P0100-36 P1103-00 P0404-72 While I can look up the first five digit codes on the net and they are quite well explained by Lorryman above, I can't find anything about the last two digits. Is there a system to them like to the first five? Is there possibly some list that explains them? Cheers Boris |
12th Jan 2012 9:07pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Hi Boris,
sent you a pm |
15th Jan 2012 12:10am |
mees Member Since: 04 Mar 2011 Location: sdijk Posts: 38 |
Yesterday I wanted to place the new bas remap. Before doing that I first checked if there were any fault codes.
The bas box found the following codes: P0404 P0299 P0606 P068a So decided not to place the remap and check first. Do I have these codes now because I connected the bas tool to read the original file into the box and can I ignore it? The turbo + manifold was replaced recently because it was warped. May be that caused the codes and the dealer did not clear them? The car did not have the remap Should I be worried? Or can I place the new bas remap on the car now |
6th Oct 2013 9:40am |
Personally I would install the map disconnect the unit as detailed. Take the truck for a spin and then rescan for codes. But that's me! I presume the truck was not running when you did the scan, in which case I would do as above?
The P404 code is EGR stuck closed. P0299 turbocharger A under boost condition P0606 engine control/powertrain module P068A fault code (ECM Power Relay Load Circuit) If you're duly worried PM Pete at BAS. If it's a new map his service is second to none and he'll sort you out. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Oct 2013 10:02am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 |
Mees, I could have answered this in a email at the same time as doing your new map or in a email after it lol. It would have saved you posting
As k9 said, just apply the new map. They could be old fault codes or non tested dtc's etc. this is where a fault code tool in some cases can cause worry to the user for no real reason Not sure if its listed in this thread already but you can find the text meaning for the tools given P codes in my web site search box. http://bellautoservices.co.uk Pete. |
6th Oct 2013 10:27am |
Hi Pete
Did not want to border you during the weekend for that reason posted the question here. But thanks for the reply. I will do that Regards Mees |
6th Oct 2013 11:29am |
Wouldn't worry about weekends..... Pete's a bit like 'stents' Click image to enlarge Keeps thing 'open' 24/7...... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Oct 2013 11:40am |
Very true hehe
6th Oct 2013 4:37pm |
FilipeFonseca Member Since: 28 Jan 2025 Location: Rio de Janeiro Posts: 1 |
Hi Alantd, I saw your comment regarding the "U0300" fault code:
"U0300 - Internal Control ModuleSoftware Incompatibility related to BAS remap but not really a problem new version are ok now, write to Pete". I live in Brazil and I own a Defender 110 Puma 2.4. Tdci 2007/08, and my mechanics has diagnostic this error code in his scanner. He is saying this is a ECU problem and that I should buy one new. If I undestood it correctly, in your comment you say this error code is related to remaping Puma engine (which I have done), and that this is "not really a problem". Could you please guide me to a solution? Thanks a lot! |
28th Jan 2025 7:13pm |
The U0300 code can be caused and is no many times by low voltage to the pcm and generally cleared its self, it can also be related to a can fault between the instrument pack and the pcm.
It should be a non invasive etc meaning it can show sometimes when fault codes are read but it takes no action to drivability on the car so is nothing to worry about on most cases of it’s seen. Quote from JLR document. U0300-00 Internal control module software incompatibility - No sub type information Incorrect hardware/software level Controller area network (CAN) circuit between the engine control module (ECM) and the instrument cluster: open circuit Check that the modules are correct for the vehicle and that the correct level of software is installed. Reconfigure the CAN system. Check the CAN circuits. Refer to the electrical guides. Rectify as necessary Pete. Click image to enlarge Click image to enlarge |
28th Jan 2025 11:19pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 528 |
Nice interprétation. My 2.2 doesn't show any fault code but U0300 (as from factory) |
31st Jan 2025 6:32am |
