Home > Technical > Fault code logs and interpretation
Page 2 of 2 <12
Lorryman100
Carried over from another thread.
bell-auto-services wrote:
An informative post Lorryman100, you have been going some homework Smile
To clarify and add to it since im in the know Mr. Green
Puma error dtc age limit is 255 Counts of key cycles before dtc is auto removed
Puma error with mill lamp on dtc age limit is 40 Counts of warm-ups before dtc is auto removed
These options are also setable and adjustable or even removable via tuning if you know where to look and what to change, every single fault type in the car is available for modification if needed.
In fact i may change the shown NON tested dtcs and their age limit before clearing in my tuning to help the user determine the real faults if any.
Funny really as ive seen landrovers updates many, many times change the (DTC filter mask) for various faults and socalled fixes they come out with. Battery monitoring was one that springs to mind on the Discovery 4
Pete
________________
Lorryman100 wrote:
Now for the stupid question Does the above counts of 255/40 key cycles mean in which the diagnostic runs without the fault reoccurring?
Yes this is normally the case.
Post #59440 16th Feb 2011 7:53pm
rusty66
Germany
additional numbers (digits 6 and 7)??
Hi,
can anyone help with the two digit codes after the general DTCs?
I've got eg
P0100-36
P1103-00
P0404-72
While I can look up the first five digit codes on the net and they are quite well explained by Lorryman above, I can't find anything about the last two digits. Is there a system to them like to the first five? Is there possibly some list that explains them?
Boris Question
Post #114762 12th Jan 2012 9:07pm
Lorryman100
Hi Boris,
sent you a pm Thumbs Up
Post #115508 15th Jan 2012 12:10am
mees
Netherlands 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Yesterday I wanted to place the new bas remap. Before doing that I first checked if there were any fault codes.
The bas box found the following codes:
P0404
P0299
P0606
P068a
So decided not to place the remap and check first.
Do I have these codes now because I connected the bas tool to read the original file into the box and can I ignore it?
The turbo + manifold was replaced recently because it was warped. May be that caused the codes and the dealer did not clear them?
The car did not have the remap
Should I be worried? Or can I place the new bas remap on the car now
Post #271778 6th Oct 2013 9:40am
K9F
Personally I would install the map disconnect the unit as detailed. Take the truck for a spin and then rescan for codes. But that's me! I presume the truck was not running when you did the scan, in which case I would do as above?
The P404 code is EGR stuck closed.
P0299 turbocharger A under boost condition
P0606 engine control/powertrain module
P068A fault code (ECM Power Relay Load Circuit)
If you're duly worried PM Pete at BAS. If it's a new map his service is second to none and he'll sort you out. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #271781 6th Oct 2013 10:02am
bell-auto-services
Mees, I could have answered this in a email at the same time as doing your new map or in a email after it lol. It would have saved you posting Smile
As k9 said, just apply the new map. They could be old fault codes or non tested dtc's etc. this is where a fault code tool in some cases can cause worry to the user for no real reason Smile
Not sure if its listed in this thread already but you can find the text meaning for the tools given P codes in my web site search box. http://bellautoservices.co.uk
Pete.
Post #271785 6th Oct 2013 10:27am
mees
Hi Pete
Did not want to border you during the weekend Smile for that reason posted the question here.
But thanks for the reply. I will do that
Regards
Mees
Post #271797 6th Oct 2013 11:29am
K9F
Rolling with laughter Rolling with laughter Bow down
Wouldn't worry about weekends.....
Pete's a bit like 'stents'
Keeps thing 'open' 24/7...... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #271800 6th Oct 2013 11:40am
bell-auto-services
Very true hehe Thumbs Up
Post #271828 6th Oct 2013 4:37pm
FilipeFonseca
Brazil 2007 Defender 110 Puma 2.4 CSW Epsom Green
Re: Fault code logs and interpretation
Hi Alantd, I saw your comment regarding the "U0300" fault code:
"U0300 - Internal Control ModuleSoftware Incompatibility related to BAS remap but not really a problem new version are ok now, write to Pete".
I live in Brazil and I own a Defender 110 Puma 2.4. Tdci 2007/08, and my mechanics has diagnostic this error code in his scanner.
He is saying this is a ECU problem and that I should buy one new.
If I undestood it correctly, in your comment you say this error code is related to remaping Puma engine (which I have done), and that this is "not really a problem".
Could you please guide me to a solution?
Thanks a lot!
Post #1058831 28th Jan 2025 7:13pm
bell-auto-services
The U0300 code can be caused and is no many times by low voltage to the pcm and generally cleared its self, it can also be related to a can fault between the instrument pack and the pcm.
It should be a non invasive etc meaning it can show sometimes when fault codes are read but it takes no action to drivability on the car so is nothing to worry about on most cases of it’s seen.
Quote from JLR document.
U0300-00
Internal control module
software incompatibility -
No sub type information
Incorrect
hardware/software level
Controller area
network (CAN)
circuit between
the engine control
module (ECM) and
the instrument
cluster: open
circuit
Check that the modules are correct for the vehicle
and that the correct level of software is installed.
Reconfigure the CAN system.
Check the CAN circuits.
Refer to the electrical guides. Rectify as necessary
Pete.
Post #1058843 28th Jan 2025 11:19pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
alantd wrote:
Glyn, Dgardel - I've taken the liberty of posting your codes and responses from an earlier thread.
P167B- Fuel Injector Learning Not Done you have done Q068 but dealer do not done injectors learning (same mounths ago LR system given errors on this procedure)
P0562- System Voltage Low battery related to the cold temp not a real problem
P068A- CM/PCM Power Relay De-Energized Performance - Too Early see previous point
P0234- Turbocharger/Supercharger "A" Overboost Condition normal on all Puma that I have seen
P1103- Mass Air Flow Sensor In Range But Higher Than Expected normal on all Puma that I have seen
P0100- Mass or Volume Air Flow "A" Circuit related to BAS remap but not really a problem new version are ok now, write to Pete
P0299- Turbocharger/Supercharger "A" Underboost Condition normal on all Puma that I have seen
U0001- High Speed CAN Communication Bus related to BAS remap but not really a problem new version are ok now, write to Pete
P1643- CAN link to ABS ECU.Implausible signal/condition
U0300- Internal Control Module Software Incompatibility related to BAS remap but not really a problem new version are ok now, write to Pete
Nice interprétation. My 2.2 doesn't show any fault code but U0300 (as from factory)
Post #1059065 31st Jan 2025 6:32am
Page 2 of 2 <12
