![]() | Home > Puma (Tdci) > broken breather hose |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2468 ![]() ![]() ![]() |
You are right. Depending on the road conditions/types you could need to clean up to the filter I would say. Puma 110" SW
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
its the fuel tank breather hose - same happened to mine, so took it in to be replaced and they changed it with an udated version which located behind a panel.
www.seabridge-marine.com |
JohanH Member Since: 13 Feb 2009 Location: Trondheim Posts: 26 ![]() ![]() ![]() |
did they clean the fuel system? Defender 110 -08
Audi UrQuattro -88 BMW 2000 touring -73 Mercedes-Benz 250 -75 Alfa-Romeo 156 -98 |
Have you had a look where they relocated it to? Thanks for the input! Cheers, Johan H Defender 110 -08 Audi UrQuattro -88 BMW 2000 touring -73 Mercedes-Benz 250 -75 Alfa-Romeo 156 -98 |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
With it broken i thas bypassed the one way valve unfortunatley !!!!we extended with extra tubing up to the roofline. might pay to look at fuel filter see if anything in it Last edited by sasha2001 on 2nd Jun 2009 6:57am. Edited 3 times in total |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
I had my tank cleaned a few days ago but I stupidly forgot to ask whether they changed the contaminated breather and ascosiated hose.
I should have insited. Makes sence that when the breather is working it will suck remaining filth back into the tank all be it much less than when the breather was in the wheel arch. Puma 110 - gone Series III 1973 - going strong |
[quote="sasha2001"][quote="JohanH"]
Have you had a look where they relocated it to? Thanks for the input! its located now up between the two panels where the rear lights are mou ted. |
