Home > Puma (Tdci) > broken breather hose
JohanH
Norway 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Hi,
found this broken hose when I had a look under the Puma. Could anyone tell me what hose it is ( I suspect it is the breather hose for the fuel tank), and what consequences this might have. I'd like to know what it is before I call the dealer.
If it is the breather for the fuel tank, what has to be done. Does the entire fuel system have to be cleaned?
Cheers,
Johan H
[/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Defender 110 -08
Audi UrQuattro -88
BMW 2000 touring -73
Mercedes-Benz 250 -75
Alfa-Romeo 156 -98
Post #11438 1st Jun 2009 10:17pm
MK
You are right. Depending on the road conditions/types you could need to clean up to the filter I would say. Puma 110" SW
Post #11440 1st Jun 2009 10:37pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
its the fuel tank breather hose - same happened to mine, so took it in to be replaced and they changed it with an udated version which located behind a panel.
www.seabridge-marine.com
Post #11441 1st Jun 2009 10:53pm
JohanH
did they clean the fuel system? Defender 110 -08
Audi UrQuattro -88
Alfa-Romeo 156 -98
Post #11442 1st Jun 2009 11:03pm
JohanH
Have you had a look where they relocated it to?
Thanks for the input!
Cheers,
Johan H Defender 110 -08
Audi UrQuattro -88
Alfa-Romeo 156 -98
Post #11444 1st Jun 2009 11:14pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Cheers,
Johan H
With it broken i thas bypassed the one way valve unfortunatley !!!!we extended with extra tubing up to the
roofline. might pay to look at fuel filter see if anything in it
Post #11446 2nd Jun 2009 5:53am
CapeLandy
South Africa
I had my tank cleaned a few days ago but I stupidly forgot to ask whether they changed the contaminated breather and ascosiated hose.
I should have insited. Makes sence that when the breather is working it will suck remaining filth back into the tank all be it much less than when the breather was in the wheel arch. Puma 110 - gone
Series III 1973 - going strong
Post #11447 2nd Jun 2009 6:34am
nicks
[quote="sasha2001"][quote="JohanH"]
its located now up between the two panels where the rear lights are mou ted.
Post #11449 2nd Jun 2009 8:46am
