Home > Puma (Tdci) > ABS/TC
symmo
2007 Defender 90 Puma 2.4 XS CSW Rimini Red
ABS/TC
I've looked through forums trying to find a definitive answer to intermittent and random ABS/TC lights coming on , the nearest I can find is a chafing wire near the "rear left outlet valve" but not knowing where it is or what it looks like it's not much help, so if someone can tell me where it is and what it looks like, or any other solutions, my dealer can not find any problem as it does not show on a diagnostic test. So any help appreciated.
Post #114105 10th Jan 2012 6:33pm
Merlin
I had exactly the same thing. It was a piece of wire jammed in the ABS unit, giving an intermittent contact. The stealership wouldn’t believe me as the fault had always gone when it went in. Hope you get it fixed, as it’s annoying seeing the TC and ABS light coming on.
Merlin
Post #114108 10th Jan 2012 6:57pm
Lorryman100
This may aid you. Thumbs Up
Post #114110 10th Jan 2012 7:12pm
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Thanks Brian, I've fired this off to my stealer.
I've had this problem for ages. The ABS/TC lights come on when my vehicle has been standing still and idling for a while. The lights go off after I have re-started and gone above 20kph.
Post #114189 11th Jan 2012 5:32am
symmo
Thanks Lorryman100 I will be contacting my dealer today wanting to know why they presume to know nothing about this, cost me £60 for them to tell me that.
Post #114205 11th Jan 2012 8:50am
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
mine had this problem try and tighten the earth wire for the abs ecu underneath the land rover
Post #114210 11th Jan 2012 9:09am
symmo
Simonpuma90, Where abouts will i find it, had this 90 from new in 07 and it's the first bit of bother i've had.
Post #114221 11th Jan 2012 9:52am
