Home > Puma (Tdci) > ABS/TC |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
I had exactly the same thing. It was a piece of wire jammed in the ABS unit, giving an intermittent contact. The stealership wouldn’t believe me as the fault had always gone when it went in. Hope you get it fixed, as it’s annoying seeing the TC and ABS light coming on.
Merlin |
10th Jan 2012 6:57pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
This may aid you.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
10th Jan 2012 7:12pm |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 |
Thanks Brian, I've fired this off to my stealer.
I've had this problem for ages. The ABS/TC lights come on when my vehicle has been standing still and idling for a while. The lights go off after I have re-started and gone above 20kph. |
11th Jan 2012 5:32am |
symmo Member Since: 22 Mar 2009 Location: BRISTOL Posts: 15 |
Thanks Lorryman100 I will be contacting my dealer today wanting to know why they presume to know nothing about this, cost me £60 for them to tell me that.
11th Jan 2012 8:50am |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 |
mine had this problem try and tighten the earth wire for the abs ecu underneath the land rover
11th Jan 2012 9:09am |
Simonpuma90, Where abouts will i find it, had this 90 from new in 07 and it's the first bit of bother i've had.
11th Jan 2012 9:52am |
