Home > Puma (Tdci) > PUMA ENGINE IDLE ROUGH, NOT ACCELERATION AND LOSS POWER
landydiesel
Saudi Arabia
Hello, I am new with this puma engine tdci. In my country for mistake the tank was filled up with water and petrol, and we make a trip. now the engine is running rough with not power at all.
we suspect that the complete injection system is damage. a lot of white smoke, take more than 15 seconds to rev from 1,000 to 3,000 rpm.
any experience? Embarassed
thank you so much.
[/b]
Post #113394 8th Jan 2012 3:28am
Bearcat
Ireland
Prepare for big bill to repair. Big Cry
Post #113401 8th Jan 2012 8:15am
richuk
Re: PUMA ENGINE IDLE ROUGH, NOT ACCELERATION AND LOSS POWER
[/b]
Water AND Petrol???? Rich
semper in excretia sumus solim profundum variat
Post #113416 8th Jan 2012 10:01am
Naks
erm, jah. I foresee new injectors, fuel pump, etc, etc. --
Post #113583 8th Jan 2012 7:12pm
bell-auto-services
It does sound as though you damage the fuel system, try and replace the fuel filters and clean the fuel tank inside and see if it gets better.
If you can not get it repaired in warranty or need to pay then I may have some used parts that I can sell cheaper than new parts if this is the problem.
PEte
Post #113616 8th Jan 2012 8:39pm
landydiesel
Saudi Arabia
richuk wrote:
[/b]
yes, it was an tank and we thought it was diesel, but it was petrol have water on bottom, we clean out the fuel filter and still has not acceleration, gray smoke also.
Post #113680 9th Jan 2012 12:05am
landydiesel
Saudi Arabia
PEte
we clean out the fuel filter, change and fill the tank with diesel but it has white/gray smoke, not acceleration,
I checked all forum Shocked , for the used parts? do I need to configure and calibrate the injectors or pump?
today we checked injectors are bad but not as I thought, on my mind the landy must have acceleration but not power, so I am confuse. maybe I will need to change all. Big Cry
my injectors, my pump and the valve on the back of rail.
the oil is ok, I check the turbo is not working exactly as usual, maybe is damage too? petrol+oil is a bad combination.
Sad
Post #113681 9th Jan 2012 12:11am
