Home > Puma (Tdci) > PUMA ENGINE IDLE ROUGH, NOT ACCELERATION AND LOSS POWER |
Bearcat Member Since: 09 Dec 2011 Location: Dublin Posts: 57 |
Prepare for big bill to repair.
8th Jan 2012 8:15am |
richuk Member Since: 13 Nov 2011 Location: Dorset Posts: 201 |
Water AND Petrol???? Rich semper in excretia sumus solim profundum variat |
8th Jan 2012 10:01am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
erm, jah. I foresee new injectors, fuel pump, etc, etc. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
8th Jan 2012 7:12pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
It does sound as though you damage the fuel system, try and replace the fuel filters and clean the fuel tank inside and see if it gets better.
If you can not get it repaired in warranty or need to pay then I may have some used parts that I can sell cheaper than new parts if this is the problem. PEte |
8th Jan 2012 8:39pm |
landydiesel Member Since: 08 Jan 2012 Location: riyadh Posts: 3 |
yes, it was an tank and we thought it was diesel, but it was petrol have water on bottom, we clean out the fuel filter and still has not acceleration, gray smoke also. |
9th Jan 2012 12:05am |
we clean out the fuel filter, change and fill the tank with diesel but it has white/gray smoke, not acceleration, I checked all forum , for the used parts? do I need to configure and calibrate the injectors or pump? today we checked injectors are bad but not as I thought, on my mind the landy must have acceleration but not power, so I am confuse. maybe I will need to change all. my injectors, my pump and the valve on the back of rail. the oil is ok, I check the turbo is not working exactly as usual, maybe is damage too? petrol+oil is a bad combination. |
9th Jan 2012 12:11am |
