![]() | Home > Puma (Tdci) > Unused electrical connectors in the back |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi there
Some days ago I dismantled the rear speaker trim (where the rear speaker is located) and I found 3 electrical connectors not used there (I'm not have rear speakers) One of them big and the others quite little. Some idea about the purpose of those connectors? Thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
MSE
Thanks for the quick answer and sorry for my english (sometimes not too good) In fact I don't have rear speakers, so Its good to know that all ins pre-wired and an extra power socket is available down there. Do you know if this power socket is switch off with the starter? Thanks again Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5070 ![]() ![]() ![]() |
Dont worry - i cant talk your language anywhere near aswell as you can talk mine! For me the power connector just worked, some i think had to put a fuse in...i seem to recall it was straight from the battery - but im starting to doubt myself now! Mike |
I think (please post a photo): two little = Speaker i'm quite sure: the big = (with female like that - | ) is the accessory socket (sigarettes burns) Last edited by dgardel on 28th May 2009 12:45pm. Edited 1 time in total |
Thanks for all the answer.
I will try during the weekend to see if the "big" connector is powered independenlty or not. Thanks again Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2455 ![]() ![]() ![]() |
some of those cablas might be for the rear fog light that we do not have in Chile and instead the dealer fits the additional reverse light Puma 110" SW
yes it's directly connected to the battery (to the 60A fuse under the passenger seat), so you have always 12V indipendently from the ignition key position. I put a socket to it and I often charge my phone when I park the car (hidden from other eyes ![]() |
Thanks Dgardel!! Eduardo
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
spell check lad's!
![]() Series III 1973 - going strong |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I think that power socket is often used for a rear work light. It works the same way as the cigarette lighter and as said above is connected directly via a 60A socket (although the front one is then passed through a 20A fuse).
I can't find the wiring diagram for the rear one, I'm afraid. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
Eduardo,
Which side did you find this connector? Thanks. |
fuel filler cap side (right) |
Thank Alantd.
I didnt found this cable in the wiring diagram also and in fact, I like to use this connector for a working light. ![]() Bosum as dgardel said right side (see figure) ![]() Click image to enlarge Remember that mine is LHD. So, I don't know if the wiring change or not. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 ![]() ![]() ![]() |
it's not the cable for the lighting harness for towing is it? Cheers
keith puer claudius |
