Home > Puma (Tdci) > Unused electrical connectors in the back
Eduardo
Hi there
Some days ago I dismantled the rear speaker trim (where the rear speaker is located) and I found 3 electrical connectors not used there (I'm not have rear speakers) One of them big and the others quite little.
Some idea about the purpose of those connectors?
Thanks Eduardo
Post #11330 27th May 2009 5:38pm
mse
If im reading right (sorry) you dont have any speakers...well the 2 small ones will be that.
If you have a t shaped connector on the right side; this could be the spare power socket. Mike
Post #11331 27th May 2009 5:41pm
Eduardo
MSE
Thanks for the quick answer and sorry for my english (sometimes not too good)
In fact I don't have rear speakers, so Its good to know that all ins pre-wired and an extra power socket is available down there. Do you know if this power socket is switch off with the starter?
Thanks again Eduardo
Post #11333 27th May 2009 6:00pm
mse
Eduardo wrote:
MSE
Dont worry - i cant talk your language anywhere near aswell as you can talk mine!
For me the power connector just worked, some i think had to put a fuse in...i seem to recall it was straight from the battery - but im starting to doubt myself now! Mike
Post #11334 27th May 2009 6:03pm
dgardel
Italy
Re: Unused electrical connectors in the back
Eduardo wrote:
Hi there
Thanks
I think (please post a photo):
two little = Speaker
i'm quite sure:
the big = (with female like that - | ) is the accessory socket (sigarettes burns)
Post #11343 27th May 2009 8:09pm
Eduardo
Thanks for all the answer.
I will try during the weekend to see if the "big" connector is powered independenlty or not.
Post #11347 27th May 2009 10:11pm
MK
some of those cablas might be for the rear fog light that we do not have in Chile and instead the dealer fits the additional reverse light Puma 110" SW
Post #11348 27th May 2009 10:19pm
dgardel
Italy
Thanks again
yes it's directly connected to the battery (to the 60A fuse under the passenger seat), so you have always 12V indipendently from the ignition key position.
I put a socket to it and I often charge my phone when I park the car (hidden from other eyes Whistle ....)
Post #11349 27th May 2009 10:53pm
Eduardo
Thanks Dgardel!! Eduardo
Post #11350 28th May 2009 12:08am
CapeLandy
South Africa
spell check lad's! Snigger Puma 110 - gone
Series III 1973 - going strong
Post #11353 28th May 2009 6:25am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I think that power socket is often used for a rear work light. It works the same way as the cigarette lighter and as said above is connected directly via a 60A socket (although the front one is then passed through a 20A fuse).
I can't find the wiring diagram for the rear one, I'm afraid. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #11356 28th May 2009 9:31am
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Eduardo,
Which side did you find this connector?
Thanks.
Post #11358 28th May 2009 12:45pm
dgardel
Italy
Bosun wrote:
Eduardo,
Thanks.
fuel filler cap side (right)
Post #11360 28th May 2009 1:47pm
Eduardo
Thank Alantd.
I didnt found this cable in the wiring diagram also and in fact, I like to use this connector for a working light. Mr. Green
Bosum as dgardel said right side (see figure)
Remember that mine is LHD. So, I don't know if the wiring change or not.
Cheers Eduardo
Post #11361 28th May 2009 2:04pm
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
just a suggestion
it's not the cable for the lighting harness for towing is it? Cheers
keith
puer claudius
Post #11362 28th May 2009 2:11pm
