Home > Puma (Tdci) > differential oil changed - yuck
rossy
even though its only had 8000km under its belt I changed the front and rear diff oils today.
I was quite taken aback to see that the stuff that drained out was black and filthy so it felt good replacing it with new clean syntrax 75/90. Nice and easy to do as well apart from having to stand on the wrench to get the drain plugs out.
I am aware that this vehicle is being babied a bit but I can't imagine its good for the crown and pinion wheels,half shafts etc to be trudging through that garbage mile after mile so along with the gearbox oil I think its a job that will need doing annually
Post #112939 6th Jan 2012 6:02pm
doh ! *delete*
Post #112966 6th Jan 2012 7:17pm
rossy
er.. read the post sir ! Laughing
I asked previously if syntrax was fine for this application and many oil boffins said it was even though there is divided opinion over GL4/5 vs GL5 and I've always sworn by all things Castrol so in it went ! (oh, I think your firm owns castrol so everyone's happy!) Laughing
Post #112979 6th Jan 2012 7:30pm
sorry Rossy ... its a job I'm going to do shortly, I'm not familiar with Syntrax but I'll get some.
Just being lazy... how much do I need for both axles ?
Post #113003 6th Jan 2012 8:13pm
dgardel
Italy
remember that the front diff oil is black for the MoS CV joint grease dilution Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #113028 6th Jan 2012 9:22pm
rossy
the front takes 1.7 litres and the back 2.3. In reality though I don't think its possible to drain all of it out as the drain plugs are offset from the bottom of the sump. Also its a good idea to heat the oil up a little before you fill ( I left mine in front of the fire for a couple of hours first) and when you've filled up to the filler hole in each diff go for a short spin before checking the level again as some gets distributed through the system. Out of 4 litre bottles I only had about 200ml left which is about right.
Check out Castrol's website as there's been a name change for Syntrax. Its the same product but I think its now called something else !
Post #113073 6th Jan 2012 10:16pm
rossy
thanks dgardel. At least its not something bad then which is a relief. And I know you are extremely busy fitting an accoustic cover at the moment too Wink
Post #113078 6th Jan 2012 10:25pm
dgardel
Italy
NO NO,
both diffs rate for 1.6 litres each.
If you overfill the diffs (same for the gearbox) they push out the oil seals.......
2.3 litres is for the gearbox
see at page 123 of this document Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #113085 6th Jan 2012 10:44pm
rossy
thats correct dgardel - for a 90. Mine's a 110 and the rear diff on a 110 takes 2.26 litres. You had me worried there for a minute !
Post #113111 6th Jan 2012 11:34pm
dgardel
Italy
Embarassed Embarassed Embarassed
right you wrote
Rear Differential
- 90 Models 1.60 litres (3.0 pints) (1.80 US quarts)
- 110 Models 2.26 Litres (4.00 pints) (2.39 US Quarts)
Bow down Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #113114 6th Jan 2012 11:47pm
dgardel
Italy
Not yet,
busy now (holiday on the Alps) Whistle
Busy next week (for job Big Cry Big Cry )
it needs same modifications but in the next 2 - 3 weeks I'll start the mods......
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #113116 6th Jan 2012 11:51pm
rossy
thats as good an excuse as any I suppose! Laughing Enjoy !
Post #113126 7th Jan 2012 12:40am
dgardel wrote:
Not yet,
Daniele - whereabout is that in the Alps?
Post #113146 7th Jan 2012 9:19am
MK
I bet your landy is inside the cabin and you sleep in a hole in the snow........ Puma 110" SW
Post #113162 7th Jan 2012 10:11am
