Home > Maintenance & Modifications > Identify this part
mermoto
Identify this part
I found this underneath my 90XS Puma - obviously a drain plug but where does it come from?? Embarassed
Mermoto
Post #112407 5th Jan 2012 12:14pm
Lorryman100
Looks like a drain teet from the heater intake box? Have a feel under the box in the area of the arrows in the pic as there should be two drain teets Thumbs Up
Post #112410 5th Jan 2012 12:18pm
roadracingtog
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Yep, see http://www.defender2.net/forum/topic10578.html that's the plug that I mentioned. Mine was blocked with crud.
Post #112413 5th Jan 2012 12:25pm
jst
either heater or air filter box drain plug. depending on vehicle. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #112414 5th Jan 2012 12:29pm
ericvv
I also went checking and found two of those. One inside at the backside of the heater intake box which you can easily see with a flashlight after unscrewing the plastic inlet cover, and the other is on the bottom of that same heater intake box. Both of them in my case also were filled with some muck, not too bad though.
I carefully cleaned the one inside the heater intake box with a wide screwdriver covered with a piece of cotton. The one on the bottom I could squeeze open several times and recovered a few small items which had gotten stuck in it, (a small cherry stone and a small wooden stick Surprised ). You can squeeze this rubber piece open rather easily from the bottom and feel inside to make sure that it is not blocked aymore. Believe any water can easily drain again after this cleaning. Thanks for the post, was really helpful advise and good warning. For the future my new Enteq snow cover hopefully will limit the dirt getting in.
Rgds, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #112442 5th Jan 2012 1:43pm
dgardel
Italy
There is one under yhe cabin heater and you can see it here (see on top of the photo):
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #112462 5th Jan 2012 2:15pm
mermoto
Thanks Lorryman- I duly crawled under the beast this morning with lamp and yes there was the hole under the heater intake missing the bung. So with a bit of spit to lubricate said bung eased it back in to place.
While I was doing this I noticed another displaced bung that was stuck behind a pile leading in to the fuel cooler. Result - this had obviously come out of the second bung hole under the heater intake box.
Errr, no because while I was contorting my hand up underneath the box I spotted yet another bung that had been dislodged and was trapped behind the front, nearside plastic wheel arch spray guard. So I've replaced two dislodged bungs and now found a third bung without a home. Hmm, will have to go back under and see if Dgardels thought that it may have come from under the cabin is right. That doesn't look an easy place to get too, even with my long fingers Evil or Very Mad
Thanks guys - Defender2 forum is awesome Bow down
Mermoto
Post #112945 6th Jan 2012 5:31pm
mermoto
Bloody hell, looking at this picture again it looks impossible to access that bung hole as its above the transmission?? Is it accessible from above? Shocked
Mermoto
Post #112947 6th Jan 2012 5:34pm
dgardel
Italy
Mermoto
Yes from the gearlever hole.
You remove the carpet, then remove the big black sponge (noise blocker) and you car arrive with your arm......
More complicated to write than make the job :-)
IID Pro MV License
Post #112977 6th Jan 2012 6:29pm
Lorryman100
Also check the Air filter housing as there is one there, unless you have a safari snorkel that is?
Post #112984 6th Jan 2012 6:35pm
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Looks like it could be the A/C drain bung,it sits above the bell housing allowing water from the A/C unit to drain.
Thanks Ash
Post #113020 6th Jan 2012 8:05pm
Blue Boy
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Buckingham Blue
There is definitely one of those to drain the water from the air conditioning. If you crawl underneath and reach up behind the transmission you'll either find the bung or the hole. I used it to cure a water leak in the passenger footwell which only appeared when driving. By reaching up and squeezing the end of the bung, I got several litres of cold water all over me as it was blocked with crud...
Post #113081 6th Jan 2012 9:27pm
dgardel
Italy
ehmmmm..
IID Pro MV License
Post #113096 6th Jan 2012 10:04pm
Mystic Merlin
Spain 2009 Defender 110 Puma 2.4 SW Alpine White
Absolutely awesome guys !!!! I am in Malaga in Spain and if you have ever tried to get a straight answer from a spanish car dealer/ mechanic, you'd understand !!! ( Good luck !!!!) The car is due to go back in to have it sorted under warranty, but I think I will be attempting the over the gearbox gynecologist manoeuvre / crawl first, just to see if I can fix it without a mechanic knackering my pride & joy !! They were talking about taking the whole centre console out !!!! I did have a quick look, but couldn't see any obvious drainage tubes, now I know why !!!!
"I'm not a qualified Gynecologist, but I'll take a bloody good look at it fer ya !" Rolling with laughter
Thank you all so much for your time, effort & Camaraderie.
Post #265973 12th Sep 2013 12:48pm
