Home > Puma (Tdci) > Finding something new on my Landy |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
I can't do that with mine. Theres nothing under the little plastic cover. Is yours a standard radio or have you got an upgraded model? I noticed last year (when i removed it) that the build date sticker on the side of the radio was 2004. Typical LR. 130 crew cab
98 V8 Disco |
25th Apr 2009 7:34pm |
Ninetenths Member Since: 26 Mar 2009 Location: Sarf Lundun Posts: 161 |
Unmarked Aux in 3.5mm stereo jack socket under auto button. It is in handbook but I never read them.
25th Apr 2009 7:45pm |
I knew about that one, i thought you could use the one under the cover. My ECU interferes with the radio reception quite badly so i'm probably going to change the radio anyway. By the way i never look at the manual until i've tried every button first or broken something. 130 crew cab
98 V8 Disco |
25th Apr 2009 8:36pm |
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
25th Apr 2009 10:04pm |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
25th Apr 2009 10:07pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
there are 2 radio versions - one with one without (well certainly in the UK)
There is also an ipod connection pack i understand to plug in the rear. The later MP3 radios are new so shouldnt be made before 06 Mike |
25th Apr 2009 10:22pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Here it comming without radio, I have a cheap Sony but with Aux jack
Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
25th Apr 2009 10:51pm |
If you look at the LR fitting guide you'll see that the iPod connection pack is a radio re-transmitter that plugs in line with the aerial. Why didn't LR just put a better head unit? 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
26th Apr 2009 9:00am |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 |
Money, Money, Money. We replaced the speakers and the headunit. LR want like 150£ for the ipod adapter to plug into the rear. may as well just buy a better head unit 110 Tdci Double Cab
26th Apr 2009 11:08am |
There is definately one that plugs into the back and does not use the FM to transmit Mike |
26th Apr 2009 11:25am |
murrayb Member Since: 20 May 2009 Location: Hastings Posts: 20 |
I plugged my iPod into the stereo and could hardly hear anything. Turned up the volume to max and still terrible.
THEN someone pointed out that it might be an idea to turn the volume up on the ipod Doh ! |
21st May 2009 7:22am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
On our i pod when we try to tune it to an unused fm channel we get quite alot of interferance, any answers ? 2.4 90 XS
23rd May 2009 6:53am |
You havent got it on charge or by the transmission have you? Only reason i ask is when i plug the phone in and its near that or getting power from the car there is interference (not that bad though) Mike |
23rd May 2009 8:29am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6623 |
Are you using the headphone socket to get the audio out of the iPod? |
23rd May 2009 8:48am |
