Page 212 of 1380 <123 ... 211212213 ... 137813791380>
22900013A
Yesterday I washed the remains of Salisbury plan off the 110. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #111193 1st Jan 2012 9:14am
JWL
Yesterday I just added more mud to mine, Herefordshire mud this time(basic undersealing Whistle as good as the factory job Thumbs Up )
Post #111211 1st Jan 2012 11:28am
mermoto
[quote="Dave-H"]
mermoto wrote:
Yea the 'garage' does get a bit tight for space Laughing - Heres a better view of it
We have access to another 3, one about 2/3 this size ........... and 1 HUGE one over 3 times as big! Cool
All heated too Thumbs Up
Dave - I think you need to be organising a Defender2 sleep over in that shed Thumbs Up We could all drive our Defenders in and make a big circle with camping and banter in the middle Whistle
Post #111215 1st Jan 2012 12:00pm
Had a run over the plains last night with BigRuss .. very dark and very muddy
GPS came in very handy last night, the plains are very different in the dark.
MrsBigRuss took some pics
Post #111220 1st Jan 2012 12:51pm
BigRuss
Yep very slippery at times, surprised not to see any other 4x4's out last night Russell
2011MY 110 XS USW Black
Post #111269 1st Jan 2012 5:00pm
Been up the Peaks today, went for a 3.5hr 'stroll' Shocked
The 90 just got used for slinging wet and muddy gear in Cool
Post #111270 1st Jan 2012 5:06pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
As good an idea as that sounds ... you have no idea how difficult it would be to arrange [vetting/passes/vehicle shakedowns, etc etc] Whistle Guns and Landrovers .... anything else is irrelevant.
Post #111324 1st Jan 2012 8:45pm
rossy
took the kids to see Puss in Boots in Roscommon (3D helps to make kids movies bearable) then a two hour ordeal following the missus around shops with only the carrot of KFC for tea on the way home - this is what middle aged dad's Bank holidays has come to. Filled up on the way back 24.4 mpg.; Marvelled at how 6th gear is usable from 50mph on the steepest of inclines and spent the evening consuming the Hobgoblin ale bought in Tescos. Happy new year fellow consumers !
Post #111331 1st Jan 2012 9:20pm
finished fitting the 2 front door rubber seals and managed to save the fragile door cards (again Thumbs Up )
the inside of my doors already had some brown sealant, so I sprayed some dinitrol inside too. Then I fitted the entreq fuel cooler guard ..
I used small ramps and axle stands to get my rivnut tool under the vehicle.
1. check the guard will fit then spray the this part with dinitrol (or similar) (picture is black and white - daughter was fiddling with the camera!)
2. dinitrol the holes, then fit the 4 rivnuts to the cross member, then dinitrol again
3. remove front anti-roll bar fixing
4. place the plastic washers onto the dinitrolled area on the top side of the guard.
5. using the 2 front a/r bar bolts, offer up the guard and do nuts up finger tight
6. fit the 4 rear hex bolts through the plate, plastic washers and into the rivnuts
7. tighten up the a/r bar bolts
8. re-check all the nuts and bolts then dinitrol the fixings
9 fit the fuel hose clip
10 sit back and admire the guard
Post #111445 2nd Jan 2012 1:42pm
Just fitted a better antenna for the HF.
Post #111448 2nd Jan 2012 2:12pm
bob neville
What HF set up have you got Greeni ?
Bob
Post #111451 2nd Jan 2012 2:21pm
I went for a basic 706 Icom, it'll do for now! I'm just doing my foundation licence.
Post #111466 2nd Jan 2012 2:50pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Fitted Alpine speakers to replace the standard jobbies, cracking on with replacing my broken radio antenna tomorrow after work with a flexi one, one less chrome bit on my defender!!! Very Happy
Post #111566 2nd Jan 2012 7:25pm
rossy
drove to Lough Key forest park in Boyle. A good walk around the lake followed by hot chocolates in the visitor centre. This place is cris-crossed with forest walks and I was itching to take the Defender along them but alas not allowed. I totally love driving this vehicle and I envy anyone whose job involves daily use of one
Post #111570 2nd Jan 2012 7:44pm
T1G UP
been laning in a friends G4 black td5 110 around whiltshire / hampshire in a decent group. very nice but slippery and scratchy Big Cry My 110 was at home Thumbs Up
Post #111583 2nd Jan 2012 8:07pm
