Home > Puma (Tdci) > ECU Interface
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
ECU Interface
Hi
can anyone tell me if the puma has an OBD 2 interface, for reading the ECU and the like? Cheers
keith
puer claudius
Post #11048 18th May 2009 12:37pm
shingwell
Yes it does; the connector is under a flap beneath the stearing wheel along with most of the fuses and relays.
I use a Scangauge on mine, works fine (www.ukobd.co.uk).
Post #11054 18th May 2009 2:40pm
kljw
Shingwell
thanks for that. now, what can you read? and can you read the engine map? Cheers
keith
puer claudius
Post #11055 18th May 2009 3:05pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
i use a scan gauge on mine, it would be handy to leave plugged in all the time but the plug sticks out to far and thus you can't put the cover on - any solutions guys?
Post #11060 18th May 2009 5:54pm
AndrewS
The ODB socket is clipped onto the fuse box panel. Why not un-clip it. Thumbs Up
Post #11061 18th May 2009 6:26pm
mse
Or remove the pannel - buy another one and cut the socket out Mike
Post #11062 18th May 2009 6:33pm
shingwell
I just leave the cover off at the moment, may cut a hole in it in due course.
No kljw, unfortunately it can't read the engine map, or at least a scangauge can't.
The scangauge does have the facility for you to make up any command you want to send to the engine electronics as a series of bytes, and to see the results as a series of numbers, but I've no idea how to formulate a command to read part of the engine map, if indeed such a thing exists.
Just a thought: are there any Transit tools available at a reasonable price that would work for this sort of thing?
Post #11064 18th May 2009 7:35pm
nicks
i've taken the screw holding it in place, but it still won't move much.
Post #11069 18th May 2009 9:10pm
