Home > Puma (Tdci) > Oil . . . . .
Page 3 of 4 <1234>
T1G UP
its only an old transit engine!
Post #110357 28th Dec 2011 1:20pm
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Ha ha that it is!! Has got a gert big bit of metal hanging off the back to carry round know though Wink
Post #110365 28th Dec 2011 2:04pm
rossy
well the reason we are all on this forum is because we are enthusiastic about our little babies, their whims, their little ways etc as if they were eg King Charles Spaniels or something. I changed the gearbox and transfer box oils within 500 miles of the thing leaving Solihull for gods sake plus an oil change after 2k miles !
But I am well aware that there are lots of transits that have been totally abused and neglected whose owners chuck any old Censored into the sump and would certainly not lose sleep over A1 B1 low SAPS gobbledegook and yet their vehicles go on and on. Doesn't matter though. My baby's gonna get 3 oil changes a year even if the 2.4 lump is regarded as 'Pikey proof' Laughing
Post #110417 28th Dec 2011 6:20pm
dgardel
Italy
dgardel wrote:
THIS NIGHT I' WRITE SAME DATA AND COMPARISON ABOUT MY CHOICES
Combination of three things lead to metal - metal contact (oil-film breakdown) and subsequent bearing wear and failure:
(1) High torque
(2) Low RPM
(3) Low HTHS viscosity
Diesel engines have higher torques at lower RPMs and require higher HTHS viscosity in order to prevent metal - metal contact.
Through the engine wear tests using an radioisotope tracer technique, it was clarified that an HTHS viscosity of 2.6 mPa¥s was the lower limit to prevent the increasing wear. It was also found that the influence of the lowering viscosity on the wear of piston rings was larger than that on the wear of the cams and connecting rod bearings.
Watch the following figure
You could play here http://sas-origin.onstreammedia.com/origin...index.html
this evening more infos
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #110537 29th Dec 2011 10:52am
T1G UP
(1) High torque
(2) Low RPM
i have no idea what your on about but i like the spiders web thing :thumbsup:
Post #110553 29th Dec 2011 12:18pm
Bearcat
Ireland
Pikey proof or not, there is a layer within the defender community that look with distain at the "pikey" engine. I've had td5s and even a v8 hyrid 90 which was great crack but not as a daily. I've had my puma over 2 months now.......I have zero complaints. That six speed box is what I wanted when I had my td5.....motorway traveling is not a boom boom high rpm affair likewise I can now glow with the intense heat from the heating system as against a battle of when will this girl warm up up.......happy as clam here. I have no intention of chipping it either, loads of mid range punch....previous td5 I sent to allisport.......not this time around.........maybe age has caught up with me!
Post #110680 29th Dec 2011 10:54pm
Axel
Germany 2012 Defender 90 Puma 2.2 SW Keswick Green
Planning on using CASTROL Magnatec 5W-30 A1 ..... Would this also be okay for a new Td4 2.2 ??? Best Regards,
Axel
Post #110732 30th Dec 2011 10:32am
MK
Nope. You need an oil meeting the WSS M2C 934B spec. Low SAPS, having a C ACEA spec.
Castrol SLX Professional Powerflow C1 5W-30 or whatever local name has in your country. Puma 110" SW
Post #110744 30th Dec 2011 11:04am
Axel
THANKS ... just what I expected ... probably because of the DPF .... Best Regards,
Axel
Post #110749 30th Dec 2011 11:12am
wslr
https://www.defender2.net/gallery/albums/u...%20JLR.pdf
This is the Engine Oils list from the Vehicle Specification Book that JLR now have available on TOPIx. It does get changed/updated from time to time, so it isn't just set in concrete and it does get changed from time to time.
My personal take is, yes, oil is oil, but you are better off using the right one right down to the brand and type. I tend to use the Castrol products on the later vehicles, but I may use a slightly cheaper 5w30 oil which is still within the Ford specification for the older vehicles from Td5 back, but even this is a branded oil (Total Quartz).
Not so much with engine oils (more diff/trans), but I get reps visiting me telling me they have an 'equivalent' oil which gets me annoyed because usually it isn't - It's sales talk for 'It's close but cheaper'. A 75w90 oil is the same as another 75w90 EXCEPT for the additives the gearbox was designed around. I wouldn't use it on my vehicles so why would I want to use it on a customer's vehicle...
Post #110774 30th Dec 2011 12:18pm
Axel
Thanks ...
So I should be okay with this stuff here??
http://www.liqui-moly.de/liquimoly/produkt...db=web.nsf
Specifications and approvals:
ACEA C1-08
JASO DL-1
Ford WSS-M2C 934-B
TECHNICAL
DATA Viscosity class : 5W-30
Density at +15 °C : 0.850 g/cm³ DIN 51757
Viscosity at +40 °C : 53.5 mm²/s DIN 51562
Viscosity at +100 °C : 10 mm²/s DIN 51562
Viscosity index : 177 DIN ISO 2909
Flash point : 228 °C DIN ISO 2592
Pour point : - 36 °C DIN ISO 3016
ASTM color number : 3 DIN 51578
HTHS viscosity : >2,9 mPas ASTM D 4683
Total Base Number : 6,0 mg KOH/g DIN ISO 3771 Best Regards,
Axel
Post #110780 30th Dec 2011 1:04pm
MK
Almost water, but yes. That is the one you need. Very good brand. Puma 110" SW
Post #110781 30th Dec 2011 1:08pm
Axel
Thanks! Bow down Best Regards,
Axel
Post #110783 30th Dec 2011 1:20pm
ericvv
Just see this thread now, and it relates to my todays started thread about gearbox, transfer case and differentials oil changes for a 2008 Puma, so what would be helpful would be the following:
Do you also have the up to date Topix Oil list for a Puma Defender for gearbox oil, transfer case oil and for the differentials?
Tks in advance, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #111336 1st Jan 2012 9:42pm
wslr
Eric - Here you go. Defender is the last page again.
https://www.defender2.net/gallery/albums/u...icants.pdf
Post #111355 1st Jan 2012 10:52pm
Page 3 of 4 <1234>
