![]() | Home > Maintenance & Modifications > Auxiliary wiring |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Very neat and tidy job
philp Member Since: 21 Oct 2008 Location: surrey Posts: 22 ![]() ![]() |
A nice, neat bit of wiring and connecting
Bullet Member Since: 21 Apr 2009 Location: Benoni Posts: 7 ![]() ![]() ![]() |
Very nice piece of work there "the boy"
![]() ![]() ![]() ![]() Please keep us in the loop (excuse the punt) when you do your next task ![]() |
Very neat
![]() 1968 1/32 scale Britains 109 Pick up. |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
A nice job.
![]() Where have you connected the other end of the earth lead (which I assume is the clear insulated cable)? Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 ![]() ![]() ![]() |
Very nice, got me thinking now. I am going to do the same I think - thanks for the inspiration.
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
The earth is direct from the battery terminal (photo 13) and yes it is clear type. I believe the cables are what all the young guys use to power their power amps so they can ruin ther hearing (speeking as a farther of three such teenagers). I think they are either 70 o 80 amp rated but I have fused at 50 which should be more than enough. Boy |
Great job there Chap
Andrew you quite right there and i thought long and hard about where to locate it. I don't generally do prolonged wading, nothing more than a river crossing in the Pyrenees or the Alps. I also looked under the drivers seat and thought "I should me concerned about that stuff than my stuff" ![]() ![]() ![]() ![]() ![]() So anyway that where I am. As an after thought Andrew where did you take the trigger feed for you lights as the next job (of many) is to fit the switch pannel into the dash. Boy |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
I have done the same as you but I have taken out the plastic cup holders fwd of the cubby box and fitted an aluminium flat plate and mounted two Hella sockets and one cigaret lighter fitting which are all switched. Saves me loosing power to the GPS everytime I shut off the ignition.
I think seeing your pictures that I am going to fit a proper fuse box instead of the loose in line fuses however to look more professional. Great job though - love that heat shrink stuff - I discovered it for the first time the other day and use it on all my connections. Puma 110 - gone Series III 1973 - going strong |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Puma 110 - gone Series III 1973 - going strong |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 ![]() ![]() ![]() |
CL........I see you fitted a split charge solinoid Q: where did you fit the aux battery?
cheers alan. |
The deep cycle is in the load bay in a battery box as the one supplied by LR is just too big to fit another next to it unless I would have had to buy two new smaller batteries.
I see some of you have two in the battery box but in RSA our batteries are huge. Cheers James Puma 110 - gone Series III 1973 - going strong |
