Home > Puma (Tdci) > Oil . . . . .
Page 2 of 4 <1234>
BigRuss wrote:
bpman wrote:
MK wrote:
why do you stick to Castrol?
Guess who owns Castrol ?
I know I know Whistle
the shareholders Thumbs Up
Post #109853 24th Dec 2011 8:44pm
rossy
Castrol's website now recommends Edge 0-30 for the Puma. Thumbs Up
Post #109859 24th Dec 2011 9:06pm
Axel
Germany 2012 Defender 90 Puma 2.2 SW Keswick Green
My Owner's Manual just says: SAE 5W-30 ..... No additional specs or brands mentioned .... Sad ... just a general remark that LR "recommends" Castrol .... Best Regards,
Axel
Post #110177 26th Dec 2011 10:37pm
MK
So no ACEA Cx spec for the DPF.. Puma 110" SW
Post #110180 26th Dec 2011 10:47pm
which castrol edge ? which puma (2.2 or 2.4) ?
Post #110187 27th Dec 2011 7:46am
dgardel
Italy
Remember that A5/B5 (low HTHS) is ONLY FOR fuel economy!!!!!
IS ALWAYS BETTER A HIGH HTHS OIL!!!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #110191 27th Dec 2011 8:44am
MK
Yes, but usually a higher HTHS goes along with higher kinematic viscosity. So in this way you can step on the excesive wear zone for an engine designed to run with low visc oils. Solution: use a "true" synth Group V oil. Puma 110" SW
Post #110194 27th Dec 2011 9:05am
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
Which one you suggest ? What do you think about the Mobil 1 5W-30 ESP ?
Post #110276 27th Dec 2011 8:24pm
MK
I think dgardel has been using such Mobil 1. The other ones are Motul Xmax 5w-30 or Motul LL 025B. Puma 110" SW
Post #110280 27th Dec 2011 8:41pm
rossy
just normal edge as opposed to turbo diesel edge. It doesn't mention engine size but I guess that covers both engines because until recently it advised Magnatec and then changed presumably because of the 2.2 DPF requiring a higher grade oil. I would therefore conclude that as edge is superior (and dearer) than Magnatec its OK for both. But I will continue to use Magnatec as I bought gallons of it dirt cheap (and so did some of the other guys I think when Halfords were giving it away recently Thumbs Up
Post #110283 27th Dec 2011 8:50pm
wslr
Magnatec (Trade name GTX Professional) 5w30 for the 2.4 and Td5 - To Ford WSS-M2913-B (or C)
Edge 5w30 for the 2.2 with DPF to Ford WSS-M2C934-B
Post #110338 28th Dec 2011 11:31am
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Thumbs Up
I use also (now into engine) Castrol EDGE 5W-30 A3/B3 A3/B4 C3
THIS NIGHT I' WRITE SAME DATA AND COMPARISON ABOUT MY CHOICES Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #110350 28th Dec 2011 1:05pm
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Ha I love this place, a simple question, a simple answer, no Censored knows Wink ha ha
Post #110353 28th Dec 2011 1:15pm
I have some Castrol Edge A5/B5 0w30 - not going to use it until my warranty expires although it is a better spec that magnatec A1
Post #110354 28th Dec 2011 1:15pm
MK
Is that a low SAPS? I stay away from those. Puma 110" SW
Post #110355 28th Dec 2011 1:17pm
Page 2 of 4 <1234>
