![]() | Home > Puma (Tdci) > My first experience change a wheel in the Defender.. |
Mark.I think the rear step his mounted on riv nuts. 2.4 90 XS
My 2007 was the same, the rear step bolts were just pulling though the bottom of the crossmember. |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Mine doesn't feel particularly strongly attached either. Does anyone have a solution? Re-attaching it with stronger bolts? Remove it all-together?
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Presumably re-attach with a spreader plate One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
mhasting2004 Member Since: 07 Dec 2008 Location: Gosford Posts: 29 ![]() ![]() ![]() |
Yep looks like rivnuts. The cross member is 2mm thick and IMHO the rivnuts are not used in a very sensible fashion. The flange of the nut is on the bottom so all that you have on the interior is the bulge of the rivnut. This would be fine in a sheer application but not in a straight pull out as is the case for the step. HAve they always been like this? My old TD5 didn't have a rear step... think I'll give this one the flick and make a proper step/rear bumper/wheel carrier.
Sure hope the tow pack is properly mounted! Cheers Mark |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 ![]() ![]() ![]() |
So was mine - infact it pulled enought to leave a gap and went in and fixed under warranty. Ill see if i can find a pic or 2. The problem is the pillar jack has now been removed in favour of the bottle jack...now i happen to have both and cant use the pillar on the rear anyway, but ignoring the std concern, my concern is those of us with NAS spec pumpers which use those holes as 2 of the main 4 restraint bolts. Mike |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 ![]() ![]() ![]() |
Hi there,
My defender come back on friday with the crossmenmer jacking point repaired. Looks quite well and as I saw, they reinforced all the points to do not have the problem again. Regarding the rear step, mine also uses rivnuts that was taking away in a rough road some time ago (very weak in my opinion). I change it by a normal bolts with a spreading plate to do not damage the cross member. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Glad you got it sorted Ed
![]() 1968 1/32 scale Britains 109 Pick up. |
