Home > Td5 > Noise+TC light when cold and left lock applied |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
I know that. hence why I said top/bottom. Nanocom might say sensor fault but that doesnt explain the groan (as you mentioned jst) |
19th Dec 2011 8:17pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Hence why it's with the indy for them to investigate Jon - 110 td5 [sold]. Currently Defenderless. |
19th Dec 2011 8:25pm |
osf ABS sensor replaced - road tested from cold and no groan or TC light/chatter
Indy did comment groan could have been ABS pump but they initially were suspecting clutch from my description over the phone but then couldn't recreate the noise after she arrived with them warmed up. In the end, they kept her overnight, sorted the sensor then ran her from cold to try to re-create the conditions of the groan and she's been fine ever since. For peace of mind, osf hub also stripped down and inspected along with cv. All fine Bearings & cv regreased and new seals/gaskets fitted. Jon - 110 td5 [sold]. Currently Defenderless. |
22nd Dec 2011 12:41am |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
Good news and at least an easy fix.
Ben 2002 Defender 110 DC |
22nd Dec 2011 12:24pm |
