![]() | Home > Td5 > Noise+TC light when cold and left lock applied |
I know that. hence why I said top/bottom. Nanocom might say sensor fault but that doesnt explain the groan (as you mentioned jst) |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Hence why it's with the indy for them to investigate ![]() |
osf ABS sensor replaced - road tested from cold and no groan or TC light/chatter
![]() Indy did comment groan could have been ABS pump but they initially were suspecting clutch from my description over the phone but then couldn't recreate the noise after she arrived with them warmed up. In the end, they kept her overnight, sorted the sensor then ran her from cold to try to re-create the conditions of the groan and she's been fine ever since. For peace of mind, osf hub also stripped down and inspected along with cv. All fine ![]() |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
Good news and at least an easy fix.
Ben 2002 Defender 110 DC |
