![]() | Home > Maintenance & Modifications > puma transmission upgrades |
paulgrs2 Member Since: 11 Dec 2011 Location: Pickering, North Yorkshire Posts: 39 ![]() ![]() ![]() |
Has anyone had there puma gearbox, t/box and/or diffs strengthened? If so any recommendations?
Thanks in advance. ![]() |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
you can upgrade to 4 pin diffs. tb and gearbox are strong enough i'd say. |
Any idea of what the upper limit torque wise the g/box and t/box can sensibly cope with? Road use car mainly. |
not a clue! why do you ask? |
Just planning a project I am doing next year with a 110 build and need to factor the transmission into the engine output. |
There has been some discussion about the Puma gearbox (aka "MT82" and made in China) Many people don't have problems... mine is crap and quite a number are replaced under warranty. Ashcroft are beginning to rebuild the standard MT82 and may be able to provide an HD version (from the Transit) at some point in the future. Incredibly, Ford also put the MT82 into their newer Mustangs ![]() ![]() ![]() http://mustangsdaily.com/blog/2011/11/09/f...nsmission/ Ford clearly have some issues to sort out... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
speak to pete bell about either 5 cyl tdci, tdv6 or tdv8 as he's done them..well not the 5 cylinder yet on a manual box although i believe it was a D3 manual box And IMHO autos the way to go! |
Bit of a petrolhead myself so probably going that route rather than the fluid of satan lol. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2464 ![]() ![]() ![]() |
360 Nm max torque (nominal) Puma 110" SW
then look at the zulu! i's personally go LS1 with te80 box and atlas twin stick transfer so rwd as a daily and 4wd for the wet. |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
[quote="blackwolf"]Puma 2-pinion front diff is definitely NOT up to the job - just replaced my seized and disintegrated unit with an Ashcroft ATB diff. Details and photos on another thread.
Replacing the diff has improved the gearchange enormously. ......how can changing a diff improve your gear change ![]() ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17713 ![]() ![]() ![]() |
The Puma's notoriously variable gearchange is greatly affected by driveline faults especially backlash. When I bought mine the gearchange was awful, a replacement clutch of the new type was big improvement but it still wasn't great, replacing worn rear halfshafts and drive flanges made a further improvement, but after changing the diff I finally have a really good gearchange; it is smooth, progressive, and doesn't snatch or clunk at all. |
Ain`t won the lottery lol. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
That's very interesting. Did you get new front and rear diffs or just the front? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
