Home > Maintenance & Modifications > Improved Door Mirrors
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Since I need wider mirrors to see past my camper I fitted Wolf 10" arms and larger heads however the paint peeled they corroded (Not OEM) and the mirrors wobbled above 40mph, due to being mounted on a ball at the bottom.
So I investigated alternative and found that Britax make suitable mounts with the same 60mm spacing between the bolts (Britax are the OEM for LR mirrors) these consist of a tubular arm and a head that is back mounted.
They dont wobble and I can swing them out to be the equivalent of a 9" arm when the camper is mounted. All are approved and E marked so no issues with MOT.
Part Numbers are:
Mirror Head 7180.301.A
Mirror Arm 7200.025.A
See Britax Website http://www.britax-pmg.com
Britax dont sell direct so I purchased through http://www.soloeng.com
Would be quite easy to fit secondary blind spot mirror and heated mirrors.
Richard 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #108667 20th Dec 2011 11:40am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Blimey those in the first photo would be good for taking out pedestrians... on the opposite side of the road!! Shocked
Post #108775 20th Dec 2011 6:14pm
110SEB
I hope you sent the first lot back for a refund.
Post #108820 20th Dec 2011 8:46pm
RFT
Yes I did and the same happened to the replacements... That is when I learnt the lesson of after market quality. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #108834 20th Dec 2011 9:30pm
