Home > Puma (Tdci) > Shocks |
Still haven't gotten around to fitting mine so haven't studied them in detail yet. However, I've just extracted the following from the Koni adjustment manual:
To be honest, I'm probably going to pay somebody else to do it Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Dec 2011 9:05pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Thanks Darren
Bob |
14th Dec 2011 9:10pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5739 |
You press a button on the top of the cylinder and rotate!
From memory Andy |
14th Dec 2011 9:56pm |
Had my 110 serviced yesterday and finally had my Koni's fitted. The ride is much improved - much less harsh over regular lumps and bumps and better body control around corners Darren
14th Jul 2012 3:57pm |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 |
How did you set the rebound? Soft, Medium or Firm? Assuming you have standard springs how is it with and without weight in the back? If you had the back laden for a holiday would your setting still be stiff enough? Mark |
23rd Jul 2012 3:20pm |
All set to soft for now, with original standard springs. Without any significant weight in the back, which is its' usual state, it's absolutely fine. Much less harsh over bumps and generally more compliant.
You'll have to wait a few days for an answer to the second part of you question, though. We're going on holiday on Friday and it'll be loaded with bikes and various other 'holiday' stuff and we'll be hanging a large twin axle caravan on the back, which should be a suitable test I last had Koni's fitted to a 300tdi Discovery, which was kitted out for overland travel. On that, they were set to soft on the front and hard on the back, which was great when loaded, but quite harsh when empty, although that was with HD springs on the rear. The spring rates and rear axle weight of a 110 is very different form a Discovery, so it's difficult to compare them though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
23rd Jul 2012 7:22pm |
Thanks Darren.
Just fitted the Koni's last night. What a difference! Can't wait to change the front. Just goes to show what garbage land rover fit! Mark |
25th Jul 2012 10:10am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
vancluse, LRA - can you confirm the type of Kon's you're fitting to the 110's? I feel the credit card is getting worried - I think I'll bite the bullet.
Already fitted 110 CSW springs (to my USW) and it has made a small improvement, the Koni's will hopefully add icing to the cake Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
25th Jul 2012 10:24am |
These
http://shop.defenderbits.co.uk/defender-ko...-191-p.asp Give Andrew a ring and he will supply the ones for a Puma, in fact I think they are the same as the ones on the site. I purchased my front and rear shocks from him. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
25th Jul 2012 11:11am |
Hi Martin, Koni 8240-1182spx heavy track for rear 07 puma 110 SW. Cheapest is flatdog but they haven't any stock Next best paddocks who have one set left Mark |
25th Jul 2012 11:25am |
Heavy Track for me too. I bought two of mine from Defender Bits as I was in the area but, including postage, Paddocks had the best deal at the time. The other two I got for a bargain price via eBay, which I appreciate doesn't help at all Darren
25th Jul 2012 12:15pm |
thanks, chaps, off on hols this Friday, but I'll order some on return... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
25th Jul 2012 2:23pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Heavy tracks here as well. well worth the cost. i still have them set to the soft setting which is fine for my fairly light loads.
But will be off to France for 2 weeks on Friday so will be a bit heavier than normal. BM52 |
25th Jul 2012 9:29pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2218 |
HI i kept my 2006 110 csw on origonal springs but put 2 inch blocks under the front and 1 inch blocks under the back spring plates . this levels the vehicle perfect and a set of pro comp gas shocks . Transformed the ride . cornering and looks . I will be doing exactly the same on my brand new 2012 2.2 110 xs next week .
16th Aug 2012 8:56pm |
