Home > Puma (Tdci) > SVX Tail Turn Indicators Position |
beetroot Member Since: 15 Dec 2008 Location: manchester Posts: 41 |
On the SVX the indicators are in a different position to normal, land rover originally were going to use all LED rear lights hence the one in the press photos having all LED's but they could not get them to work or something, so they used a normal bulb for the indicators. As the normal bulb light fitting looks different to the LED ones used for stop/tail and reverse/fog they moved the position of the indicator and swapped it with reverse/fog position so the different looking units were not all jumbled up.
At the end of the day you are right the indicator is not in the right position, if you want you can now swap the normal bulb indicator to LED but you must swap the front indicator bulb to LED (can put one in original housing) and get a special LED flasher relay (to stay legal get one that has a warning if a unit stops working, not that an LED will as often as a normal bulb) Then you can put them back in the correct positions. Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
11th May 2009 8:02am |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
heres the posistion on mine with led units -
Click image to enlarge just swop the flasher unit for an electronic one, the one i have will flash normal bulbs as well as led Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
11th May 2009 11:41am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6632 |
Not LEDs, but this is my layout with incandescent NAS lights:
11th May 2009 12:42pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
There is a technical bulletin out about LED lights. Actually relates to trailer boards but it mentions that the fix (not yet available) will address the use of LED lights on the main vehicle.
Can't remember the specifics (might try and dig it out later) but it might have been to do with the ECU. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
11th May 2009 3:52pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2443 |
Any idea of the price for each led unit?
thanks M Puma 110" SW ............................................................. Earth first. Other planets later |
11th May 2009 6:00pm |
