Home > Technical > damaged transmission housing?
Page 3 of 4 <1234>
jst
whats the clutch fluid level like? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #106430 12th Dec 2011 6:18pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Glynparry25 wrote:
LR90XS2011 wrote:
if thats the clutch bell housing then I would suspect the engine crank shaft oil seal . like Feteke states I wouldnt worry but keep an eye on it and the oil levels, if it is engine oil check that all the breathers are clear and the crank case is not pressurising (noticable pressurised air flow out of the filler cap when removed with engine running)
Clutch fluid- All clutch items (which contain oil) are on the outside of the bell housing therefore there shouldn't be any clutch fluid inside there.
Glyn there is a slave cylinder inside the bell housing that can leak clutch fluid Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #106484 12th Dec 2011 8:32pm
Glynparry25
Shocked Just checked and you are right!!.... So I have thought back to the past 13 years or working on vehicles and realised that I have never in that time changed a slave cylinder on a Land Rover..... Just loads of regular cars.
So, add to the checks.... Clutch fluid. Any mechanic would be able to tell the difference in about 3 seconds whether it is engine oil of clutch fluid. So a quick pop down to see one would clear that up.
Glyn Dog Sheep
Post #106550 13th Dec 2011 6:39am
fekete
On the td5 it was on the out side Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #106589 13th Dec 2011 10:03am
Glynparry25
Every day is a school day Mr. Green
Glyn Dog Sheep
Post #106590 13th Dec 2011 10:06am
fekete
Laughing Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #106591 13th Dec 2011 10:08am
TheTechnobear
Spain 2007 Defender 110 Puma 2.4 SW Chawton White
Clutch fluid is (very) full, so if its that then it must be loosing very.
Saying that I don't appear to be loosing engine oil ,
Will keep an eye on both.
Otherwise will leave, until Next time I go to the garage, I'll get them to check it and fix ... Will report back Smile
(assuming it doing no further damage, or is not going to suddenly let go... and leave me stranded somewhere)
Post #106677 13th Dec 2011 3:42pm
jst
what can look like a lot of oil/fluid can in fact not really be much in the scheme of things. our 200tdi leaks from the rear engine oil seal enough to mean the chassis back from there will never rust but you dont see a noticeable change in engine oil level over the 12mths between changes (about 4k miles) Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #106755 13th Dec 2011 8:46pm
Scallops
Australia
To replace or repair the clutch slave cylinder - if it's inside the bell housing, is it a gearbox out to fix this?
Post #108560 19th Dec 2011 9:59pm
jst
no, you can do it in situ, the slave will come out complete, just make sure the plastic collar comes with it! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #108562 19th Dec 2011 10:13pm
fekete
You are correct Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #108563 19th Dec 2011 10:13pm
Scallops
Australia
How do you actually get to it if it's in the bell housing?
Post #108825 20th Dec 2011 9:06pm
jst
making a wild assumption that the puma one is similar to a tdi - (and i havent checked microcat on this) but if that the case the slave is bolted to the outside of the bellhousing but protrudes through and into the bell housing. undo the bolts and extract it. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #108832 20th Dec 2011 9:25pm
Scallops
Australia
Just another thing for technoBear....I I discovered again, that my Puma had further oily looking material in the same spot......but this time I have found my vehicle's issue. The nipple on the front of the prop shaft was firstly loose, secondly had lost the ball bearing in it's end. It was spraying a swath of honey coloured like stuff (thin oil) - on the chassis rail and in direct line with this lower part of the bell housing. I tightened the nipple, wrapped electrical tape around the nipple just to be sure, cleaned it all up - problem found and "fixed". I'll get it sorted next service.
Maybe if your mechanic is stumped, look into this for yours. Wink
Post #109041 21st Dec 2011 11:29pm
Scallops
Australia
Could the OP maybe give us an update on this please? I've now found that I had 2 problems. I've replaced the nipple that was throwing a liquid grease substance, but there is oil seeping from the same spot - mainly evident after the vehicle sits for a while.
I'd like to know what the mechanic found on yours TB!
Post #112677 5th Jan 2012 9:34pm
Page 3 of 4 <1234>
