![]() | Home > My New Defender (L663) > Coolant Loss and "shunty" gearbox. |
Yorkshire90 Member Since: 22 Sep 2011 Location: West Yorkshire Posts: 200 ![]() ![]() |
Sorry, just realised this is absolutely in the wrong place 😑
![]() Click image to enlarge New 6cyl 3.0 Diesel. Only covered 2.5k. That seems like a lot of coolant lost on my father's 90. He's been to the dealership. Booked in Tuesday for a check. Won't provide him with a top up. He's too concerned about buying an incorrect coolant as I believe it's SiOAT and nothing seems to come up compatible locally. Dealer suggested topping up with water. No thanks. "Yes... They all use coolant...it's normal" No it isn't. Gearbox also has a clunk, a shove you feel in your seat when engaging drive and setting off. Also rolls back on hills about 30cm. Are they meant to hold position? Again, "they all do that" from customer service. A brand new 60k motor. Seems worrying to me. Thoughts and advice? Even if it's directing to a safe coolant. I have some Comma G40 OAT (Pink)...not sure. [/url] "Big green" 2000 Td5 90 IRB Developments modified (2004-2011) Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much* IRB Developments rebuild: Project Ice cube 2012-...... http://www.defender2.net/forum/topic11056.html |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 166 ![]() ![]() |
The JLR Spec for coolant is: STJLR.651.5003
Try Opie Oils https://www.opieoils.co.uk/search.aspx?search=STJLR.651.5003 Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
Thanks for the feedback. We'll it's been topped up today at LR. Will keep a check on it. Diagnostics not throwing anything up with the gearbox. The rolling back issue is because the hill start feature wasn't activated
![]() ![]() Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much* IRB Developments rebuild: Project Ice cube 2012-...... http://www.defender2.net/forum/topic11056.html |
jenzz Member Since: 14 Dec 2024 Location: Frankfurt Posts: 7 ![]() ![]() |
Yes, check out the "Faults and Fixes" Section, you're not alone. |
