Home > My New Defender (L663) > Coolant Loss and "shunty" gearbox.
Yorkshire90
Sorry, just realised this is absolutely in the wrong place 😑
New 6cyl 3.0 Diesel. Only covered 2.5k. That seems like a lot of coolant lost on my father's 90. He's been to the dealership. Booked in Tuesday for a check. Won't provide him with a top up. He's too concerned about buying an incorrect coolant as I believe it's SiOAT and nothing seems to come up compatible locally.
Dealer suggested topping up with water. No thanks.
"Yes... They all use coolant...it's normal" No it isn't.
Gearbox also has a clunk, a shove you feel in your seat when engaging drive and setting off. Also rolls back on hills about 30cm. Are they meant to hold position? Again, "they all do that" from customer service.
A brand new 60k motor. Seems worrying to me.
Thoughts and advice? Even if it's directing to a safe coolant. I have some Comma G40 OAT (Pink)...not sure.
[/url] "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much*
IRB Developments rebuild: Project Ice cube 2012-......
http://www.defender2.net/forum/topic11056.html
Post #1062843 13th Mar 2025 10:00pm
WizzardPrang
The JLR Spec for coolant is: STJLR.651.5003
Try Opie Oils https://www.opieoils.co.uk/search.aspx?search=STJLR.651.5003 Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1062846 13th Mar 2025 10:57pm
ruben
Spain
Not so much, but something similar happens around here... although not as low, it only went down halfway between MAX and MIN in 15,000 km, I didn't see the problem with topping up with distilled water as the dealer advised me, taking into account that the Havoline XLC coolant, esp.STJLR.651.5003, is a lot of liters and that it is diluted at 50% and, in addition, that it only needed 150cc to reach the MAX level, I don't see the problem in that, I wasn't worried about the matter anymore and there, in the MAX, it is still several thousand km later. Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1062848 13th Mar 2025 11:29pm
Yorkshire90
Thanks for the feedback. We'll it's been topped up today at LR. Will keep a check on it. Diagnostics not throwing anything up with the gearbox. The rolling back issue is because the hill start feature wasn't activated Laughing I thought all autos held position when in drive on an incline? Obviously not Very Happy "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Post #1063286 18th Mar 2025 5:39pm
jenzz
Germany
Re: Coolant Loss and "shunty" gearbox.
Thoughts and advice? [/url]
Yes, check out the "Faults and Fixes" Section, you're not alone.
Post #1065237 10th Apr 2025 3:26pm
mse
the roll (forward and back) is a problem many of us have...it wasnt on my last 2 it is on this, worse on the courtesy car and i would say its dangerous
you can make it easier but its still a pain. Mike
Post #1065490 14th Apr 2025 5:31pm
