Home > Maintenance & Modifications > HELP Defender 90 window going way too low
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey friends I need some help. My right window in my D90 rolls down way too low. I noticed the drivers side has a distinct stopping point that prevents the window going too low. However the right side will go all the way until it hits the bottom of the door frame? I would love any suggestions.
 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #1064705 4th Apr 2025 11:34pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi
Have you compared the drivers side mechanism to the passenger side one? It could be that one of the stops has bent or is missing?
Jim
Post #1064716 5th Apr 2025 6:35am
Soulrider911
Thanks Jim, where exactly is the stop? That is what I had assumed the problem is, but I don't know what I am looking for. 1989 Defender 90
Post #1064756 5th Apr 2025 3:54pm
Dinnu
IIRC, there is a tooth on the sector that is bent sideways, presumably to limit movement. But not sure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1064765 5th Apr 2025 5:43pm
It may have jumped a couple of teeth down, that’s what I’d be wondering. WeWillWin🇬🇧🇺🇸
Post #1064771 5th Apr 2025 6:16pm
Soulrider911
Thank you to gain access to the limiter to i need to take the inner door panel off? Thank you 1989 Defender 90
Post #1064774 5th Apr 2025 6:35pm
Dinnu
I think if you wind the glass all the way up, you would see that part of the sector gear just below the inner panel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1064780 5th Apr 2025 7:34pm
Soulrider911
Thank you for the help, is this this area you are referring to:
 1989 Defender 90
Post #1064782 5th Apr 2025 7:40pm
That’d be it, it might have skipped some teeth, to sit a bit lower than it should.
Could be wear, and or when door slammed. Should be greased though, is it dry? WeWillWin🇬🇧🇺🇸
Post #1064786 5th Apr 2025 8:02pm
Dinnu
Yes thats the tab I refer to.
I normally grease mine. Not sure if its the right thing to do though as sometimes dirt and dust can act like grinding paste. Had gears become really pointy, but they still last me decent amount of years. A dry lubricant is probably more suited. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1064805 6th Apr 2025 6:07am
I just used lithium grease, I found when I last had a look they were completely dry, mind you like the wiper wheel boxes, they need doing I’d say very rarely, so I’d say about the same rate as wiper wheel box replacement.
I suppose that’d be about 6 to 10 years ish WeWillWin🇬🇧🇺🇸
Post #1064845 6th Apr 2025 3:16pm
