Home > Puma (Tdci) > 2.4 TDCI DCU-106 / DCU-102 EGR OFF Winols Solution?
Page 3 of 3 <123
boazbd
Israel
Thanks for the explanation. In the OLS file you attached the closest I could find is "multiplier to egr valve dmd" and it's value is "00016" which you mentioned is originally set to "1".
Is this actually the parameter you meant should be set to "0" in order to cancel the EGR operation on PUMA engines?
Thanks again.
Post #1064715 5th Apr 2025 6:34am
Page 3 of 3 <123
