L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10946 ![]() ![]() |
Good news with the mot pass ![]() Yep your not to far behind ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Thank you spudfan and CarMan
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 104 ![]() ![]() |
Splitting some logs
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4763 ![]() ![]() |
Bit the bullet and cleaned out the 110
Never again will I let the 110 go six months without a regular interior cleaning. ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20726 ![]() ![]() |
Itโs probably safe to say Spud wonโt skip doing that job again for so long.
![]() โฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
Seems so much more room inside it now....
![]() On a different note saw some oil on the ground so had a look from the classic "lying on your back" Land Rover position. Seems to be from the area of the seal on the crankshaft pulley. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 597 ![]() ![]() ![]() |
Fitted a new radiator that you can't see in the picture ๐. But a big thanks to this forum, it provided the info I needed to get it done. ๐
Looking good for a 14 year old engine bay. ![]() Click image to enlarge |
Funny enough I was doing engine bay cleaning the other day too.
![]() Has anyone had any strange finds? I have found a grease nipple cover in the round cup holder part on top of the engine, and a white cable guide under the engine cover, as I took mine off to give the top of the block a clean. Has anyone else found any strange items before? I bet there has been. WeWillWin๐ฌ๐ง๐บ๐ธ โฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
Some years ago I had a bad smell coming into the 200 tdi. Turned out to be a dead cat in the radiator cowl. Was not a pleasant job getting it out..... 1982 88" 2.25 diesel
Birds nests in barn finds are quite common as well, especially fun if they get hot, luckily with no inhabitants.
But the heat and combustible material isnโt a good mix. ![]() โฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 332 ![]() ![]() ![]() |
I pressure washed the inner wings under the bonnet and a live rifle round landed on the floor.
Once there were three females in the house (wife and two daughters) now down to two females. Decided to tidy up the cubby box one day. Removed a bra, pyjamas and sanitanary products. Have not done a cubby box tidy up since
