![]() | Home > Td5 > electrical connector crimp pins |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1645 ![]() ![]() |
i know martyn supplies them
but i use simtek as they are near us. send them a pic, and some info and they can normally identify the make of plug from that. https://www.simtekuk.co.uk/ very good to deal with |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 32 ![]() ![]() ![]() |
Econoseal connectors are what your looking for. Durite does them.
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 810 ![]() ![]() ![]() |
Econoseal, but there are different types
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 287 ![]() ![]() |
Many thanks for the replies.
My odbc socket was looking a bit trashed so thought id replace it... except you cant get it any more, seems to have been replaced with C2S32215. Tried an econoseal socket from a 3 pin socket ... doesnt fit. Have emailed simtek.co.uk to see if they can help. Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
Could you do anything with this?
https://www.ebay.co.uk/itm/166901115230?mk...media=COPY |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6656 ![]() ![]() ![]() |
I can supply the terminals for the OBD socket from stock.
ELVIS Member Since: 14 Jan 2025 Location: Exeter Posts: 6 ![]() ![]() |
I have boxes of OBD connectors/pins and also the covers to keep dirt out of the pins.
Message me if you get stuck. Think I buy them in at £2 per socket/cover. Pins for other plugs will probably be JP/JPT. About £6/50 for known/decent supplied ones that crimp and seal properly. 1999 TD5 110 CSW |
many thanks for the offer. I actually revistited the earthing round the ECU. Put an earth from ecu to body, then another one from battery to the seat box on the other side. Plugged in the nanaocom I'd just bought and everything worked just fine.
May actually revidit the odbc plug at some point and replace with new one but other things to do at the moment ![]() A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
