Home > Td5 > Three Amigos and friends
rustandoil
Thursday's journey home from work in my 2005 TD5 110 I was accompanied by the three amigos, who brought some friends along in the shape of.....
No fuel gauge, no speedo or odometer no stereo and the air-con fan (internal) running very slowly despite being switched off.... Everything else seemed to work.
Thought I heard a "buzzing sound" from the rear.... Since learnt that this could be a wheel sensor?
Following day I had "crank no start" Nanocom said "fuel pump drive open"... I dont know if thisis a new fault, but I've been nursing a fuel pump relay base problem for a while... Re-seat the relay and all is well normally for a few weeks or so ...
.... Restart and three amigos had gone but reappeared a short time into my next trip, they were intermittently on and off for the 10 mile journey... Had to stop for half an hour, restart was with intermittent three amigos after a 10 mins we had air-con fan on slowly and now with battery /sulphur smell... Luckily we were not to far from where I could leave the Defender with the battery disconnected and borrow the company van...
Apologies for the story book, but I thought the more information the better Very Happy
So where do I start?.... Forum search suggests check the earth points, I can do that and look for obvious damage, but beyond that I'm a bit stuck.
Any suggestions from the electric system wizards? Bow down
PS I don't like electrics much Big Cry
Post #1064177 29th Mar 2025 7:59am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi
How old is the battery? ha sit been allowed to totally discharge at any point? is your alternator good?
Jim
Post #1064178 29th Mar 2025 8:20am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Oil in loom?
I’ve replaced mine twice in 12 years , both times symptoms were different.
All sorts of odd things going on ,temperature gauge , idling at high revs etc etc.
Simple to check (and free!) 2002 td5 90 county hardtop
Post #1064183 29th Mar 2025 10:21am
rustandoil
Thanks for the replies..
Not much time to work on this yesterday... But I can say the battery is less than 18 months old and has been looked after... And checks out with a battery tester.
Alternator is the factory unit, so coming up 20 years old 🤔
No oil in loom, and the earth points under the driver's seat are checked and good.
I'll continue with the earth point checks, but having just completed a refresh of the whole vehicle I'm confident they are ok.
Post #1064226 30th Mar 2025 7:09am
landy andy
Sulphur smell from battery tends to be an over charge. So possibly your alternator is not regulating its output. And I question if with a high voltage that other items may be shut down as protective thing by the ecu????
Can you test your alternator output?
Post #1064230 30th Mar 2025 9:26am
rustandoil
I will check the voltage across the battery whilst driving, probably using Nanocom....once Ive completed my earth point checks...is there any other way to check alternator output?
Post #1064286 31st Mar 2025 9:01am
