Home > General & Technical (L663) > GAP tool question
lightning
GAP tool question
l have a question that l don't think anyone has asked yet.
Are changes made with the GAP tool classed as modifications? So for instance if you activate dynamic mode, added configurable terrain response, enabled stop/start memory, and enabled the wi-fi hotspot. Do you need to tell your insurance?
lt's worth considering what would happen if the vehicle was in an accident and then could they wriggle out of paying due to "undeclared modifications"
They are not physical changes but for instance activating "dynamic mode" might be seen as similar to a remap, and any excuse the insurance back room boys might find to avoid paying out.
Post #1063999 27th Mar 2025 8:37am
Munchie
When I spoke to admiral about modifications they said anything physical or electrical that wasn’t present when the car was manufactured. The definition of electrical wasn’t defined, but if they treat a engine tune as electrical I’m sure they’d treat other modifications as electrical - provided they’d look for them and then cross reference it back to the build of the car, some energy but cheaper than a 60-80l payout.
Post #1064001 27th Mar 2025 8:45am
lightning
Well, that's what l was thinking. lt wouldn't be the time to find out. l am sure the "get out of paying" department are well aware of these forums and may even monitor them, although it would be difficult to identify actual owners as the details are not public.
Post #1064054 27th Mar 2025 7:21pm
Munchie
Agreed I guess it depends on the value of payout. I decided this year to declare a tune on my Ftype because of the risk of saving a few hundred quid on insurance outweighed the risk of investigation after an accident.
Post #1064079 27th Mar 2025 9:58pm
stevemfr
France
I am not familiar with UK insurance regulations but I do want to clear up what it is that CCF editing does vs a (true) electronic modification such as a remap.
Editing the CCF is akin to making a change in the settings menu in the Pivi. The difference is that Land Rover does not provide the settings menu to CCF settings - these must be provided with an outside tool (and, on a tangent, AFAIK the only 2 systems that enable this are LR's Pathfinder system and the IIDTool. The others on the market are Chinese copies of LR software). So everything you are activating on the vehicle by editing the CCF was already installed ex-factory.
A remap on the other hand constitutes flashing modified or new software to whatever ECU is to be changed: a engine remap, transmission remap, etc. This SW did not leave the factory already installed on the vehicle and a remap does alter the vehicles performance parameters to a state outside of that which LR certified for the Defender's production.
I disagree with Admiral's blanket assessment of "anything that wasn't present". Imagine, for instance, that LR had the different performance levels of the D200, 250, 300 and 350 as CCF settings. The SW would have been present ex-factory, but any reasonable person would agree that gong from 200 to 350hp would constitute a modification.
IMHO, CCF editing does not constitute an insurance relevant vehicle modification as there is no CCF setting that, on its own (w/o the addition of physical parts) modifies the performance parameters of a vehicle. Even things such as Dynamic Mode as this does not alter the vehicles performance per se but simply alters how the vehicle's controls react to driver inputs. Tesla, for instance, allows similar changes in the standard vehicle settings menus.
But as I said above, I am not an expert on UK vehicle insurance.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1064109 28th Mar 2025 11:15am
Munchie
Good insights. Does a dealer update overwrite the ccfs?
Post #1064158 28th Mar 2025 10:10pm
pjeski
United States
Not in my experience. Even when they were adding my trailer hitch module, and making changes. My changes all remained.
Post #1064187 29th Mar 2025 12:24pm
